- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Partially applied types and sort-polymorphism
- Date: Mon, 06 Aug 2012 09:06:41 -0400
On 08/05/2012 08:51 PM, Jason Gross wrote:
Adam: that sounds like it would work, but it's not clear
to me how to formalize it. Do you have an example, or more details you
could give me? Does the following address your issue? Parameter Category : forall (objC : Type), (objC -> objC -> Type) -> Type. Parameter Functor : forall objC homC, Category objC homC -> forall objD homD, Category objD homD -> Type. Definition functorLike := forall objC homC, Category objC homC -> forall objD homD, Category objD homD -> Type. Definition type : functorLike := fun _ _ _ _ _ _ => Type. Definition arrow (F G : functorLike) : functorLike := fun _ _ C _ _ D => F _ _ C _ _ D -> G _ _ C _ _ D. Infix "-->" := arrow (right associativity, at level 100). Definition NaturalTransformationType : functorLike := Functor --> Functor --> type. Eval compute in NaturalTransformationType. On Fri, Aug 3, 2012 at 8:20 AM, Adam Chlipala <adamc AT csail.mit.edu> wrote:
Jason Gross wrote:
Why not define a new [->]-like operator that does the quantification
in its definition? Basically, the game is to abstract out common
quantification patterns into operators.For example, it would be nice if I could not have to say that a natural transformation was of type NaturalTransformation : forall objC homC (C : @Category objC homC) objD homD (D : @Category objD homD), @Functor objC homC C objD homD D -> @Functor objC homC C objD homD D -> Type and instead say that a NaturalTransformation was of type NaturalTransformation : forall (C : @Category _ _) (D : @Category _ _), @Functor C D -> @Functor C D -> Type |
- [Coq-Club] Partially applied types and sort-polymorphism, Jason Gross, 08/02/2012
- Re: [Coq-Club] Partially applied types and sort-polymorphism, Arnaud Spiwack, 08/03/2012
- Re: [Coq-Club] Partially applied types and sort-polymorphism, Jason Gross, 08/03/2012
- Re: [Coq-Club] Partially applied types and sort-polymorphism, Vladimir Voevodsky, 08/03/2012
- Re: [Coq-Club] Partially applied types and sort-polymorphism, Adam Chlipala, 08/03/2012
- Re: [Coq-Club] Partially applied types and sort-polymorphism, Jason Gross, 08/06/2012
- Re: [Coq-Club] Partially applied types and sort-polymorphism, Adam Chlipala, 08/06/2012
