- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Reserved Notation bug?
- Date: Fri, 17 Aug 2012 17:34:15 +0200
Le Thu, 16 Aug 2012 18:16:40 -0400,
Jason Gross
a écrit :
> Can someone explain to me what is happening in the following code (in
> particular, in the last line)? Is this a bug?
> Parameter foo : Type -> Type -> Type -> Type.
> Parameter bar : Type -> Type -> Type.
> (* Notation "C ~ D" := (bar C D). (* Error: A left-recursive notation
> must have an explicit level. *) *)
> (* Notation "C .^{ M } D" := (foo C M D). (* Error: A left-recursive
> notation must have an explicit level. *) *)
> Reserved Notation "C .^{ M } D" (at level 70, no associativity).
> Reserved Notation "C ~ D" (at level 70, no associativity).
> Notation "C ~ D" := (bar C D). (* works fine *)
> (* Notation "C .^{ M } D" := (foo C M D) (at level 70, no
> associativity). (* would work fine *) *)
> Thanks.
> -Jason
I guess it is a bug. Replacing curly braces makes it work:
Reserved Notation "C .^« M } D" (at level 70, no associativity).
Notation "C .^« M } D" := (foo C M D).
Reserved Notation "C .^{ M » D" (at level 70, no associativity).
Notation "C .^{ M » D" := (foo C M D).
Reserved Notation "C { M } D" (at level 70, no associativity).
Does not work either, and intertingly reports that '{' and '}' are not
considered as symbols. I tried to escape them between (single) quotes,
but it did not work either.
This also works :
Reserved Notation "C .^{ M .^} D" (at level 70, no associativity).
Notation "C .^{ M .^} D" := (foo C M D).
But this does not:
Reserved Notation "C .^{ M }^. D" (at level 70, no associativity).
Notation "C .^{ M }^. D" := (foo C M D).
So use of curly braces seems to be following some particular rule.
I do not remember this in the documentation, and I believe that braces
in Notations used to work…
- [Coq-Club] Reserved Notation bug?, Jason Gross, 08/17/2012
- Re: [Coq-Club] Reserved Notation bug?, AUGER Cédric, 08/17/2012
