- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] decidability and all that
- Date: Wed, 29 Aug 2012 15:59:13 +0200
Hello friends.
Consider the following definition
Inductive def : Type :=
| Cons1 : nat -> list nat ->def.
Now, let's say I want to prove decidability of this structure's equality. Trivially, the following does work.
Lemma def_dec:
forall d d': def, {d = d'} + {d <> d'}.
Proof.
intros.
repeat decide equality.
Qed.
Now, say we have this definition instead:
Inductive def :Type :=
| Cons1 : list def -> def.
The above proof would not work in this case. In fact, since I'm using repeat, it would actually never terminate.
As you've guessed by now :), I would like to know what is the approach you guys use for proving decidable equality of inductive definitions with self-referenced projections.
On a related note: I use CoqIDE and it does not seem to have any way to kill the current applied tactic, meaning that for the above infinite scenario I have no other way besides killing the application and restart it. Right?
Please note that this 'problem' may also arise in situations like 'repeat inversion H; subst', which is something that I use from time to time..
What's your input on that? I should treat using 'repeat' as some kind of "bad practice" or? Yeah, I know some of you could tell me that I should know beforehand what are the effects of the tactic before applying it :), but the thing is that sometimes I forget how I defined the structures and in the case of repeating inversions it was not that easy to predict - consider a respectable number of hypothesis in your context.
Anyway, some thoughts please :)
Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600 dollars last year.
Marge: Bart! Don't make fun of grad students, they just made a terrible life choice.
- [Coq-Club] decidability and all that, Nuno Gaspar, 08/29/2012
- [Coq-Club] Re: decidability and all that, Nuno Gaspar, 08/29/2012
- Re: [Coq-Club] decidability and all that, AUGER Cédric, 08/29/2012
- Re: [Coq-Club] decidability and all that, Nuno Gaspar, 08/30/2012
