- To: "psperatto AT adinet.com.uy" <psperatto AT adinet.com.uy>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] inductive
- Date: Wed, 29 Aug 2012 15:58:45 -0400
On 08/29/2012 03:54 PM, psperatto AT adinet.com.uy wrote:
Do you know if there is some paper or book that presents the definition of the rec, rect, ind (the elimination and equality rules) from the type former and construction rules of an inductive set (type, prop)? If I understand your question correctly, then this is the scholarly citation that I use (pulled from the author's web site): @inproceedings{Moh93, author = {C. Paulin-Mohring}, booktitle = {Proceedings of the conference Typed Lambda Calculi and Applications}, editor = {M. Bezem and J.-F. Groote}, institution = {LIP-ENS Lyon}, note = {LIP research report 92-49}, number = 664, series = {Lecture Notes in Computer Science}, title = {{Inductive Definitions in the System {Coq} - Rules and Properties}}, type = {research report}, year = 1993 } |
- [Coq-Club] inductive, psperatto AT adinet.com.uy, 08/29/2012
- Re: [Coq-Club] inductive, Adam Chlipala, 08/29/2012
