coq-club - Re: [Coq-Club] Coq and RSI
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Coq and RSI
  • Date: Tue, 04 Sep 2012 10:04:30 +0200
- find an emacs way to exchange _ and - in my keyboard layout (a
particular instance of the following point)
I would use xmodmap to switch keys, to ensure that you have the
changed layout in all applications.
- find a way to shorten the number of key presses required to write
proof scripts
I insert many tactics with just two keys presses. For instance
"` o" inserts "omega.", "` s" inserts "simpl." and so on. For more
complex tactics I query arguments from the minibuffer, eg. "` m"
inserts "decompose [ex and or] H; clear H.", where the assumption
H is queried in the minibuffer.
The idea is borrowed from Pvs: some rarely used key (`) is made a
prefix key in Emacs, such that you can bind commands to key
sequences starting with `.
For copying bigger amounts of text, especially for generalize, I
use the virtual cursor of package vcursor.el. With it you can
navigate a second cursor in the goals buffer and then copy text
from there to the proof script without touching the mouse or
loosing your real cursor position.
Bye,
Hendrik
