- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Dependent lexicographic product wellfoundedness without eq_rect_eq
- Date: Wed, 5 Sep 2012 16:56:42 -0700
I just noticed that the standard library's
Wellfounded.Lexicographic_Product.wf_lexprod depends on the eq_rect_eq
axiom. However, it's not very difficult to prove it without any
axioms:
Require Import Relation_Operators.
Require Import Transitive_Closure.
Section WfLexicographic_Product.
Variable A : Type.
Variable B : A -> Type.
Variable leA : A -> A -> Prop.
Variable leB : forall x:A, B x -> B x -> Prop.
Notation LexProd := (lexprod A B leA leB).
Lemma lexprod_inv_right : forall (x:A) (y:B x) (P : sigT B -> Prop),
(forall (x':A) (y':B x'), leA x' x -> P (existT B x' y')) ->
(forall y':B x, leB x y' y -> P (existT B x y')) ->
forall pr:sigT B, LexProd pr (existT B x y) -> P pr.
Proof.
intros.
revert H H0.
refine (match H1 in (lexprod _ _ _ _ pr0 existT_x_y) return
(let (x0, y0) return Prop := existT_x_y in
(forall (x':A) (y':B x'), leA x' x0 -> P (existT B x' y')) ->
(forall y':B x0, leB x0 y' y0 -> P (existT B x0 y')) -> P pr0) with
| left_lex _ _ _ _ _ => _
| right_lex _ _ _ _ => _
end); auto.
Qed.
Lemma acc_A_B_lexprod :
forall x:A,
Acc leA x ->
(forall x0:A, clos_trans A leA x0 x -> well_founded (leB x0)) ->
forall y:B x, Acc (leB x) y -> Acc LexProd (existT B x y).
Proof.
induction 1; induction 2; constructor.
inversion 1 using lexprod_inv_right; intros.
apply H0; trivial.
intros; apply H1; eauto using clos_trans.
auto.
Qed.
Theorem wf_lexprod :
well_founded leA ->
(forall x:A, well_founded (leB x)) -> well_founded LexProd.
Proof. (* unchanged from the standard library *)
intros wfA wfB; unfold well_founded in |- *.
destruct a.
apply acc_A_B_lexprod; auto with sets; intros.
red in wfB.
auto with sets.
Qed.
End WfLexicographic_Product.
Daniel Schepler
- [Coq-Club] Dependent lexicographic product wellfoundedness without eq_rect_eq, Daniel Schepler, 09/06/2012
