- To: Daniel Schepler <dschepler AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] the type of [sum]
- Date: Mon, 10 Sep 2012 20:20:40 -0400
So this means that any inductive type with more than one constructor lives in at least [Set]?
I'm still confused, though. I get the following in coqtop
Set Printing Universes.
Inductive sumT (A B : Type) :=
| inlT : A -> sumT A B
| inrT : B -> sumT A B.
Inductive sumP (A B : Type) : Prop :=
| inlP : A -> sumP A B
| inrP : B -> sumP A B.
Check sumT.
(* sumT
: Type (* Top.77 *) ->
Type (* Top.78 *) -> Type (* max(Set, Top.77, Top.78) *)
Check sumP.
(* sumP
: Type (* Top.91 *) -> Type (* Top.92 *) -> Prop
My intuition says that if something can be forced to be in [Prop], the type-checker shouldn't infer it to necessarily be higher?
-Jason
On Mon, Sep 10, 2012 at 1:21 PM, Daniel Schepler <dschepler AT gmail.com> wrote:
Because from the sum P+Q, you can extract some information (whichOn Mon, Sep 10, 2012 at 9:43 AM, Jason Gross <jasongross9 AT gmail.com> wrote:
> Hi,
> Can someone explain to me why the type of [sum] is
> [Type (* Coq.Init.Datatypes.33 *) ->
> Type (* Coq.Init.Datatypes.34 *) ->
> Type (* max(Set, Coq.Init.Datatypes.33, Coq.Init.Datatypes.34) *)]
> In particular, why is the [sum] of two propositions in [Set], rather than in
> [Prop]?
branch an element comes from), which would be illegal for the
disjunction proposition P\/Q. P+Q is equivalent to the type {P} + {Q}
=def= sumbool P Q, which is the more usual one to use for Props.
Daniel Schepler
- [Coq-Club] the type of [sum], Jason Gross, 09/10/2012
- Re: [Coq-Club] the type of [sum], Daniel Schepler, 09/10/2012
- Re: [Coq-Club] the type of [sum], Jason Gross, 09/11/2012
- Re: [Coq-Club] the type of [sum], Daniel Schepler, 09/11/2012
