- To: <coq-club AT inria.fr>
- Subject: [Coq-Club] equivalence between different classes
- Date: Wed, 19 Sep 2012 16:00:10 +0200
Hi,
I am experimenting with type classes and categories, and there is a basic point that is not still clear for me:
I defined a category class:
Class Category (Ob: Type) (Hom: Ob->Ob->Type) (Eqv: forall {a b}, (Hom a b) -> (Hom a b) -> Prop) (Id: forall ob, Hom ob ob) (Comp: forall {a b c}, Hom a b -> Hom b c -> Hom a c) := { eqv_equivalence : forall a b, Equivalence (@Eqv a b); comp_proper : forall a b c, Proper (@Eqv a b ==> @Eqv b c ==> @Eqv a c) Comp; comp_associativity : forall `(f: Hom a b)`(g: Hom b c)`(h: Hom c d), Eqv (Comp (Comp f g) h) (Comp f (Comp g h)); id_left_identity : forall `(f: Hom a b), Eqv (Comp (Id a) f) f; id_right_identity : forall `(f: Hom a b), Eqv (Comp f (Id b)) f }.
And then I was trying to define a monoid as a category with a single object:
Class Monoid (Carrier: Type)(Eqv: Carrier -> Carrier -> Prop)(One: Carrier)(Comp: Carrier -> Carrier -> Carrier) := underlying_category :> Category unit (fun _ _ => Carrier) (fun _ _ => Eqv) (fun _ => One) (fun _ _ _ => Comp).
This class is „equivalent” to a monoid:
Instance Nat : Monoid nat eq O plus. repeat split; repeat auto with *. Qed.
But in reality, looking at the definition ( Print Monoid ), you can see that this is in reality a category built using the unit set of objects.
The question is: IS THERE ANY SIMPLE WAY TO SAY TO COQ THAT THE TYPE unit->A IS ISOMORPHIC TO A, AND THEN THE CLASS OBTAINED BY SUBSTITUTING unit->unit->A WITH A WILL HAVE THE SAME INSTANCES?
IS IT POSSIBLE TO FIND THE „NORMAL FORM” OF THE CLASS ( THE ONE CONTAINING THE TYPE A ) AUTOMATICALLY ?
Best regards, Daniele
- [Coq-Club] equivalence between different classes, Daniele Pucci, 09/19/2012
- Re: [Coq-Club] equivalence between different classes, Gregory Malecha, 09/19/2012
