- From: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Variant of [rewrite] that ignores type universes?
- Date: Fri, 21 Sep 2012 15:05:36 +0200 (CEST)
Hi !
I have the same problem here : it is particularly annoying to rewrite an equality that contains Type instances, if these instances are not the same in the equality and in the goal !
The same problem exists when trying to use all the tactics that search for a subterm in the goal.
Is this a bug or a feature ?
If this is a feature, is there a good work-around ?
De: "Jason Gross" <jasongross9 AT gmail.com>
À: coq-club AT inria.fr
Envoyé: Jeudi 19 Juillet 2012 23:12:50
Objet: [Coq-Club] Variant of [rewrite] that ignores type universes?
Hi,Is it a known/desired behavior that [rewrite] fails to match [Type]s in different universes? (I'm using Coq 8.4beta2.) Is there a way to tell [rewrite] to turn off it's universe strictness?For example, I have the following code:Set Printing Universes.Goal Type = Type.pose Type as a.assert (H : Type = a) by reflexivity.(* rewrite H. (* "Found no subterm matching "Type (* Top.8 *)" in the current goal." *) *)match goal with| [ H : ?x = _ |- ?x = _ ] => idtac x (* Type (* Top.8 *) *)end.match goal with| [ H : ?x = _ |- ?y = _ ] => let H' := fresh inassert (H' : x = y) by reflexivity;rewrite <- H'; clear H';rewrite H (* succeeds *)end.Thanks.-Jason
- Re: [Coq-Club] Variant of [rewrite] that ignores type universes?, Jacques-Henri Jourdan, 09/21/2012
