- To: Coq Club <coq-club AT inria.fr>
- Cc: Adam Chlipala <adamc AT csail.mit.edu>
- Subject: Re: [Coq-Club] Interest in Coq-based mathematics classes?
- Date: Mon, 24 Sep 2012 09:15:12 -0700
Inspired by this discussion, I've mocked up something that might be
able to serve as the beginnings of a combinatorics module for such a
class (and for Coq more generally).
Require Import Program.
Require Import List.
Generalizable All Variables.
Class Decision (P:Prop) : Set :=
| decide : {P} + {~P}.
Implicit Arguments decide [[Decision]].
Definition decideb (P:Prop) `{Decision P} : bool :=
if decide P then true else false.
Notation "'Yes'" := (left _ _).
Notation "'No'" := (right _ _).
Notation "'Reduce' x" := (if x then Yes else No) (at level 90).
Program Instance True_dec : Decision True := Yes.
Program Instance False_dec : Decision False := No.
Obligation Tactic := program_simpl; tauto.
Program Instance and_dec `{Decision P} `{Decision Q} :
Decision (P /\ Q) :=
if decide P then
Reduce (decide Q)
else
No.
Program Instance or_dec `{Decision P} `{Decision Q} :
Decision (P \/ Q) :=
if decide P then
Yes
else
Reduce (decide Q).
Program Instance not_dec `{Decision P} : Decision (~P) :=
if decide P then No else Yes.
Program Instance impl_dec `{Decision P} `{Decision Q} :
Decision (P -> Q) :=
if decide P then
Reduce (decide Q)
else
Yes.
Obligation Tactic := program_simpl.
Program Instance Forall_dec `{forall x:A, Decision (P x)} :
forall l:list A, Decision (Forall P l) :=
fix Forall_dec (l : list A) : Decision (Forall P l) :=
match l with
| nil => Yes
| x :: l' => if decide (P x) then
Reduce (Forall_dec l')
else
No
end.
Solve Obligations using (program_simpl; red; inversion 1; auto).
Program Instance Exists_dec `{forall x:A, Decision (P x)} :
forall l:list A, Decision (Exists P l) :=
fix Exists_dec (l : list A) : Decision (Exists P l) :=
match l with
| nil => No
Yes
else
Reduce (Exists_dec l')
end.
Class EqDec (A:Type) : Type :=
| eq_dec :> forall x y:A, Decision (x = y).
Instance bool_eq_dec : EqDec bool.
intros x y; red; decide equality.
Defined.
Class Enumeration (A:Type) : Type :=
| elements : list A.
Implicit Arguments elements [[Enumeration]].
Definition finite_card (A:Type) `{Enumeration A} : nat :=
length (elements A).
(* I'm not sure whether it's better to require the enumeration be
exhaustive and have no duplications, before allowing the application
of this notation. *)
Notation "# A" := (finite_card A) (at level 0).
Instance sum_enum `{Enumeration A} `{Enumeration B} :
Enumeration (A + B) :=
map inl (elements A) ++ map inr (elements B).
Fixpoint list_prod `(l1 : list A) `(l2 : list B) : list (A * B) :=
match l1 with
| nil => nil
| x :: l1' => map (pair x) l2 ++ list_prod l1' l2
end.
Instance prod_enum `{Enumeration A} `{Enumeration B} :
Enumeration (A * B) :=
list_prod (elements A) (elements B).
Instance sig_enum `{Enumeration A} `{forall x:A, Decision (P x)} :
Enumeration (sig P) :=
(fix filter (l : list A) : list (sig P) :=
match l with
| nil => nil
| x :: l' => match decide (P x) with
| left p => exist P x p :: filter l'
| right _ => filter l'
end
end)
(elements A).
Instance bool_enum : Enumeration bool := [ false; true ].
Example size_bool : # bool = 2.
Proof. lazy. reflexivity. Qed.
Example size_sig_bool : # { b:bool | andb b false = b } = 1.
Instance prod_dec `{forall (x:A) (y:B), Decision (P x y)} :
forall p:A*B, Decision (let (x,y):=p in P x y) :=
fun p => match p with
| pair x y => decide (P x y)
end.
Example size_bool_le_rel :
#({ (x,y):bool*bool | andb x y = x }) = 3.
(* For some applications, such as sig when we're not assuming
proof irrelevance, we might need to allow A to be a setoid and
adjust this definition accordingly. *)
Class ExhaustiveEnumeration (A:Type) `{Enumeration A} : Prop :=
| exhaustivity : forall x:A, In x (elements A).
Instance bool_enum_exhaustive : ExhaustiveEnumeration bool.
Proof.
intro x; destruct x; simpl; auto.
Qed.
Program Instance forall_finite_dec `{ExhaustiveEnumeration A}
`{forall x:A, Decision (P x)} : Decision (forall x:A, P x) :=
Reduce (decide (Forall P (elements A))).
Next Obligation.
rewrite Forall_forall in H2.
auto.
Defined.
Next Obligation.
auto.
Defined.
Program Instance exists_finite_dec `{ExhaustiveEnumeration A}
`{forall x:A, Decision (P x)} : Decision (exists x:A, P x) :=
Reduce (decide (Exists P (elements A))).
Next Obligation.
rewrite Exists_exists in H2.
destruct H2 as [x [? ?]]; exists x; trivial.
Defined.
Next Obligation.
red; destruct 1 as [x ?].
apply H2.
rewrite Exists_exists.
exists x; split; auto.
Defined.
Ltac proof_by_decision :=
match goal with
| |- ~ ?P =>
let dec := (eval hnf in (decide P)) in
match dec with
| left _ => fail "statement being negated is true"
| right ?np => exact np
| _ => fail "could not decide statement"
end
| |- ?P =>
match dec with
| left ?p => exact p
| right _ => fail "statement is false"
end
end.
Example demorgan_bool : forall x y:bool,
negb (andb x y) = orb (negb x) (negb y).
Proof.
proof_by_decision.
Qed.
Daniel Schepler
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, (continued)
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Benjamin Werner, 09/18/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Pierre Courtieu, 09/18/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Adam Chlipala, 09/19/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Jonas Oberhauser, 09/20/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Kristopher Micinski, 09/20/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Wolfram Kahl, 09/20/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Freek Wiedijk, 09/20/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Julien Narboux, 09/20/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Daniel Schepler, 09/24/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, bertot, 09/25/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Daniel Schepler, 09/25/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Adam Chlipala, 09/25/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Adam Chlipala, 09/26/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Jason Gross, 09/27/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Andrej Bauer, 09/27/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Daniel Schepler, 09/28/2012
- Re: [Coq-Club] Interest in Coq-based mathematics classes?, Andrej Bauer, 09/28/2012
