coq-club - Re: [Coq-Club] Uninstall Coq 8.4
  • From: Pierre Boutillier <pierre.boutillier AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Uninstall Coq 8.4
  • Date: Wed, 03 Oct 2012 10:53:45 +0200
  • Organization: INRIA
Hi,
No there is not.
I think the main reason for that is that no developper wants to take the
responsability to write a rule that implies some sudo rm -rf /usr/stuff
In a perfect world, anyone would either compile coq for
develloping/testing and use ./configure -local (so no make install) or
install it using a package manager that handle the uninstall phase. In
reality, if the makefile could generate a script to uninstall what it
installs, it would be usefull. (Makefiles generated by coq_makefile does)
Pierre B.
On 03/10/2012 07:04,
mariana.bernagozzi AT gmail.com
wrote:
> Hi,
> I've installed Coq 8.4 from sources and I would like to uninstall it. I've
> already tried (with no luck):
> $ sudo make uninstall
> and
> $ sudo make deinstall
> Operating system: Ubuntu 11.10
> Is there any other way to uninstall Coq 8.4 than manually removing the files
> installed by the app?
> Thanks!
> Regards,
> Mariana
