- To: Coq-Club Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Patterns and typeclass overloaded notation?
- Date: Wed, 3 Oct 2012 17:34:47 -0400
Hi,
Using Coq 8.4 I define a typeclass just for overloading an infix
notation for application:
Class Applic (A: Set) := { app: A -> A -> A} .
Notation "m @ n" := (app m n) (at level 90, no associativity).
Here is an instance of this typeclass:
Inductive Map: Set := mx0: Map | mx1: Map | mapp: Map -> Map -> Map.
Instance Applic_Map : Applic Map := { app m n := mapp m n }.
The infix notation seems to work for this instance:
Check (mx0 @ mx1).
But when I try to define a size function for Map, the overloaded
syntax is not accepted in a pattern:
Fixpoint MapSize (m:Map) {struct m} : nat :=
match m with
| mx0 => 0
| mx1 => 0
| (m1 @ m2) => S ((MapSize m1) + (MapSize m2))
end.
Toplevel input, characters 83-90:
Error: Invalid notation for pattern.
What is the problem? If I explicitly make a notation for the type Map
Notation "m @ n" := (mapp m n) (at level 90, no associativity).
the pattern match is accepted.
Randy
- [Coq-Club] Patterns and typeclass overloaded notation?, Randy Pollack, 10/03/2012
- Re: [Coq-Club] Patterns and typeclass overloaded notation?, AUGER Cédric, 10/04/2012
