- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Frederic Blanqui <frederic.blanqui AT inria.fr>
- Cc: Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] definition accepted by coqc but not accepted by coqtop
- Date: Wed, 10 Oct 2012 10:52:27 +0200
Hi, the final try is probably the good one but you should call coqtop like this: "coqtop -top File".
In proofgeneral you can put this at the end of the file to store the right invocation of coqtop:
(* Local Variables: *)
(* coq-prog-args: ("-emacs" "-top" "File") *)
(* End: *)
Hope this helps.
P
2012/10/10 Frederic Blanqui <frederic.blanqui AT inria.fr>
Hello.
I have a problem for having both coqc and coqtop accept some definition:
Section S1.
Variable A : Type.
Inductive t := c : A -> t.
End S1.
Section S2.
Variable A : Type.
Notation c := (c A).
(* this first definition is not accepted because c is a notation:
Definition f (x : t A) := match x with c _ => 0 end.*)
(* this second definition is accepted by coqtop (ProofGeneral) but not by coqc:
Definition f (x : t A) := match x with Top.c _ => 0 end. *)
(* assuming that this code is put in file.v, then
this third definition is accepted by coqc but not by coqtop (via ProofGeneral):
Definition f (x : t A) := match x with File.c _ => 0 end. *)
End S2.
Why the second definition is not accepted by coqc?
Is there a definition that can be accepted by both coqc and coqtop, while keeping c as a notation for (c A) in section S2?
Thanks for your help.
Frederic.
- [Coq-Club] definition accepted by coqc but not accepted by coqtop, Frederic Blanqui, 10/10/2012
- Re: [Coq-Club] definition accepted by coqc but not accepted by coqtop, Pierre Courtieu, 10/10/2012
- Re: [Coq-Club] definition accepted by coqc but not accepted by coqtop, Frederic Blanqui, 10/11/2012
- Re: [Coq-Club] definition accepted by coqc but not accepted by coqtop, AUGER Cédric, 10/11/2012
- Re: [Coq-Club] definition accepted by coqc but not accepted by coqtop, Pierre Courtieu, 10/11/2012
