- To: Coq-Club Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Dependent pattern matching?
- Date: Wed, 10 Oct 2012 22:02:19 -0400
In Coq 8.4 want to represent a type "Map" that is informally given by
---------------- (* zero *)
mx0 : Map
---------------- (* one *)
mx1 : Map
n : Map m : Map (n <> mx0 \/ n <> mx1)
mcons n m : Map
So I define an index set ZZNZ (for Zero or NonZero) and the indexed type
Map:
Inductive ZZNZ : Set := ZZ: ZZNZ | NZ: ZZNZ.
Inductive Map: ZZNZ -> Set :=
| mx0: Map ZZ
| mx1: Map NZ
| mconsl: Map NZ -> Map ZZ -> Map NZ (* NZ in left part *)
| mconsr: Map ZZ -> Map NZ -> Map NZ (* NZ in right part *)
| mconsb: Map NZ -> Map NZ -> Map NZ. (* NZ in both parts *)
Now I want to define a function "mapp: Map -> Map -> Map" given by
mapp m n := if m = n = mx0 then mx0 else mcons m n
So I compute what the type of the result should be
Definition mappIndx (l r:ZZNZ) : ZZNZ :=
match l, r with
| ZZ, ZZ => ZZ
| _, _ => NZ
end.
and want to define a function
Definition mapp (l:ZZNZ) (m:Map l) (r:ZZNZ) (n:Map zr) :
Map (mappIndx l r) :=
match l, r return Map (mappIndx l r) with
| ZZ, ZZ => mx0
| NZ, ZZ => mconsl m n
| ZZ, NZ => mconsr m n
| NZ, NZ => mconsb m n
end.
This last definition is not accepted. How should this be defined?
A related question: is Matthieu Sozeau's "Equations" supported in Coq
8.4? (All the files in the git repository are years old.)
Thanks for any help.
Randy
- [Coq-Club] Dependent pattern matching?, Randy Pollack, 10/11/2012
- Re: [Coq-Club] Dependent pattern matching?, Matthieu Sozeau, 10/11/2012
- Re: [Coq-Club] Dependent pattern matching?, Benoit Montagu, 10/11/2012
