coq-club - Re: [Coq-Club] Type classes, coercions and universes
  • To: Richard Dapoigny <richard.dapoigny AT univ-savoie.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Type classes, coercions and universes
  • Date: Sat, 13 Oct 2012 16:59:13 +0200
Le Sat, 13 Oct 2012 15:30:28 +0200,
Richard Dapoigny
a écrit :
> Hi all,
> I have the following problem :
> I have introduced a hierarchy of universes such as:
> Definition Universal := Type.
> Definition Concept : Universal := Type.
> Definition Association : Universal := Type.
> Definition PT : Concept := Type.
> Definition PD : PT := Type.
> Definition ED : PT := Type.
> Then, I create some type classes :
> Class BinaryRel {A B:PT} : Association := {
> BinaryRel_arg1 : A;
> BinaryRel_arg2 : B;
> BinaryRel_struct : A->B->Prop}.
> Class OccurIn `{@BinaryRel PRO R} : Association := { }.
> Class Endocarditis `{@BinaryRel Disease Endocardium} : Association :=
> { Endocarditis_arity : SelectArity Disease (card_1
> Disease) }.
> Instance BR1 : @BinaryRel Disease Endocardium :={
> BinaryRel_arg1 := d1; (* with
> Parameter d1 : Disease. *)
> BinaryRel_arg2 := En1; (* with
> Parameter En1 : Endocardium.*)
> BinaryRel_struct d1 En1 := True}.
> Parameter End1 : @Endocarditis BR1.
> Parameter End2 : @OccurIn BR1. (* <- error *)
> And I obtain the following error message :
> Error: The term "BR1" has type "BinaryRel" while it is expected to
> have type "BinaryRel".
First thing to do in this condition is to activate printing of implicit
arguments. I often set the printing of all low level contents.
For the rest, I did not try your code, as you defined stuff in your
comments and didn't wanted to play in understanding what should be
declared as parameters.
> while there are coercion paths between respective implicit arguments :
> [u20] : Disease >-> PRO
> [r5] : Endocardium >-> R
> Is anyone has an explanation?
> Thanks in advance,
> Cheers,
> Richard
