- To: coq-club AT inria.fr
- Subject: [Coq-Club] coercions between records
- Date: Thu, 25 Oct 2012 02:10:47 +0200 (CEST)
Hello all,
I'm trying to set up a coercion between types in a record, as follows:
Require Import Setoid.
(* We have two models here, one contains a set of domain elements *)
Record first_model : Type := {
D : Set;
d_Eq : relation D
(* And the other is a Kripke-style many-worlds model, where the worlds can
be viewed as the first model. It contains principals. *)
Record second_model : Type := {
P : Set;
W : Set;
p_Eq : relation P;
s : W -> first_model;
coerce_p_to_d : forall (w : W), P -> D (s w)
(* coerce_p_to_d is supposed to be an injective function that shows that p
is a subset to d, a la Cantor. *)
Axiom coerce_p_inj : forall (M : second_model) (w : W M) (p p' : P M), d_Eq
(s M w) (coerce_p_to_d M w p) (coerce_p_to_d M w p') -> p_Eq\
M p p'.
(* The following gives: Error: coerce_p_to_d does not respect the uniform
inheritance condition. *)
Coercion coerce_p_to_d : P >-> D.
However, I get the error that I commented about above. Everything I see on
coercions has the types outside of records, however, coercions are supposed to
take any class, so it seems like this should work (P is of type forall M :
second_model, Set, etc).
Is there a way to make this work?
- [Coq-Club] coercions between records, akhirsch, 10/25/2012
- Re: [Coq-Club] coercions between records, Enrico Tassi, 10/25/2012
