- From: Thomas Braibant <thomas.braibant AT gmail.com>
- To: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Strange bihaviour with existential variables
- Date: Tue, 6 Nov 2012 14:50:02 +0100
In this particular case, doing the following solves the issue in 8.3.
Lemma l1 : exists x, pred1 x.
Proof.
simpl.
eexists.
apply l0.
(* some existential variables are still undefined here*)
Qed.
In a nutshell, doing simpl before the eexists changes the type of the
existential variable into a product, and makes it possible to apply
l0.
Thomas
On Tue, Nov 6, 2012 at 11:41 AM, Jacques-Henri Jourdan
wrote:
> Hi Coq-club !
> I have a strange behavior in presence of existential variables in my Coq
> development, and I would be happy to see whether it is well-known and
> whether there is a well-known solution. The development is quite big, so
> here is a smaller example that "somewhat" exhibits the core of what I
> identify as beeing the problem (the problems appears in both Coq 8.3pl4 and
> 8.4):
> Require Import List.
> Definition tuple (types:list Type) : Type :=
> fold_right prod unit types.
> Inductive A : Type :=
> | A_constr1.
> Definition typlst (a:A) : list Type :=
> match a with
> | A_constr1 => (nat:Type)::nil
> end.
> Definition pred0 (l:tuple nil) : Prop := True.
> Definition pred1 (l:tuple (typlst A_constr1)) : Prop :=
> True.
> Lemma l0 : forall x, pred0 x -> pred1 (1,x).
> Proof.
> eauto.
> Qed.
> When trying to execute the last tactic, Coq complains with:
> Toplevel input, characters 6-8:
> Error: Impossible to unify "(?245 * ?246)%type" with
> "tuple (typlst A_constr1)".
> Now, I actually have two problems:
> 1- I would have expected Coq to reduce "tuple (typlst A_constr1)" in order
> to unify it. It is even more frustrating knowing that the problem occurs at
> the type level, where everything is known by Coq, and where it suffices to
> reduce terms in order to unify them. I actually don't even know why it
> created those existential type variables ?245 and ?246, as there value are
> trivially known as being the types of 1 and x in l0...
> 2- In my full development, the error message is even stranger (however, I
> cannot reproduce this behavior in this smaller example): it says something
> which would be analogous to:
> "tuple ?240".
> Based on the existential variables numbering, ?240 has been created during
> the execution of eexists (it is actually "eexists t", where t contains a
> wildcard), but ?240 *has been instantiated* during "eexists", so it should
> no longer appear anywhere.
> So, what do you think ?
> Thank you,
- [Coq-Club] Strange bihaviour with existential variables, Jacques-Henri Jourdan, 11/06/2012
- Re: [Coq-Club] Strange bihaviour with existential variables, Adam Chlipala, 11/06/2012
- Re: [Coq-Club] Strange bihaviour with existential variables, Thomas Braibant, 11/06/2012
- Re: [Coq-Club] Strange bihaviour with existential variables, Chung-Kil Hur, 11/06/2012
- Re: [Coq-Club] Strange bihaviour with existential variables, Jacques-Henri Jourdan, 11/07/2012
- Re: [Coq-Club] Strange bihaviour with existential variables, Arnaud Spiwack, 11/07/2012
- Re: [Coq-Club] Strange bihaviour with existential variables, Chung-Kil Hur, 11/07/2012
