- To: Daniel Schepler <dschepler AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Stuck with functions.
- Date: Thu, 08 Nov 2012 23:45:48 +0100
Am 08.11.2012 23:03, schrieb Daniel Schepler:
On Thu, Nov 8, 2012 at 1:15 PM, Jonas Oberhauser
<s9joober AT gmail.com>
wrote:
One thing that has opened my eyes a little bit was this provable propositionI'm not sure exactly what you're trying to get at with this example.
that Smolka and CE Brown showed to me:
Goal forall X, forall f : X -> (X -> Prop), exists g, forall x, f x <> g.
What does this mean? Does it mean that there are more "sets of X" than there
are "elements of X"? Or does it just mean that there is no procedure (in the
Coq-World) that gives every procedure in (X -> Prop) a unique object of X?
Certainly you can only write down countably many procedures (or "sets") in
Coq, but the number of sets of e.g. natural numbers is much larger.
Of course it's easy to prove this without axioms:
Definition same_set {X} (A B:X->Prop) : Prop :=
forall x:X, A x <-> B x.
Lemma Cantor_diag: forall {X} (f:X -> (X->Prop)),
exists B:X->Prop, forall x:X, ~ same_set (f x) B.
But this is just a refinement of the statement that every
undergraduate math major learns. And since it's also easy to prove
A=B -> same_set A B, so ~ same_set A B -> A <> B, your statement is an
easy corollary.
Maybe I was imprecise. Within the example, I was not arguing about any axioms at all. I was talking about meaning. What is the meaning of the proposition from above? As far as I can tell, we are not making any claims about the existence of a function. We are making claims about procedures.
As soon as you assume axioms, the meaning might change. Excluded middle is another good example. "P \/ ~ P", to me, means we can prove P or we can refute P. If we can prove this (by either giving a proof of P or refuting P), we can establish this claim. Once we assume excluded middle, the meaning of "P \/ ~P" somehow changes to "P is true or is false" because certainly we do not have a proof term for every proposition or its negation (like functional extensionality, which I think is independet of XM).
So when we assume axioms, we need to make sure we understand that we change the meaning of things. Otherwise, insanity ensues. Sometimes it is not clear in what way the meaning changes.
I have no reason to believe that two procedures that compute the same function are equal. I could argue, as you say, that I can not distinguish them by the means that Coq gives to me. Maybe that is enough to claim that they are leibniz-equal in Coq, but then again, as with the example from before, how much impact does a proof of "f = g" then have in the real world? I have proven they are equal, but, you know, not really? Only in the countable Coq-world? I don't know about this...
As long as the fact that two procedures compute the same function is enough to clear the proof obligations, I would not assume such axioms. Maybe for some proof goal we have to, maybe it makes things easier. But still I have a bad feeling tingling down my spine.
Kind regards, Jonas
- [Coq-Club] Stuck with functions., Jesse Clayton, 11/08/2012
- Re: [Coq-Club] Stuck with functions., Jason Gross, 11/08/2012
- Re: [Coq-Club] Stuck with functions., Adam Chlipala, 11/08/2012
- Re: [Coq-Club] Stuck with functions., Dmitry Grebeniuk, 11/08/2012
- Re: [Coq-Club] Stuck with functions., Kristopher Micinski, 11/08/2012
- Re: [Coq-Club] Stuck with functions., AUGER Cédric, 11/08/2012
- Re: [Coq-Club] Stuck with functions., Jonas Oberhauser, 11/08/2012
- Re: [Coq-Club] Stuck with functions., Daniel Schepler, 11/08/2012
- Re: [Coq-Club] Stuck with functions., Daniel Schepler, 11/09/2012
- Re: [Coq-Club] Stuck with functions., AUGER Cédric, 11/09/2012
- Re: [Coq-Club] Stuck with functions., Alan Schmitt, 11/08/2012
- Re: [Coq-Club] Stuck with functions., Robbert Krebbers, 11/08/2012
- <Possible follow-up(s)>
