- From: Kenneth Adam Miller <kennethadammiller AT gmail.com>
- To: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- Cc: coq-club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Coq data types
- Date: Sun, 11 Nov 2012 18:03:00 -0600
Thank you so much, Pierre, for a direct and specific answer. And for the additional links! :)
But I have a problem in that I can't do Require Vector in the version of CoqIDE that I'm tied to (8.3pl2). I get an error: Cannot find library Vector in loadpath
On Sun, Nov 11, 2012 at 4:13 PM, Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr> wrote:
Hi,
the purpose is to write this module in the Ocaml style. It means that you mustn't Import this module.
You only
Require Vector.
then you write as in Ocaml Vector.hd, Vector.nth Vector.fold_left … (This is supposed to be the meaning of the first comment. Maybe, I should rephrase it.) So as in Ocaml, the data structure defined in the module Module has name Module.t.
As far as I don't understand C, you want a kind of http://coq.inria.fr/distrib/V8.4/stdlib/Coq.Init.Datatypes.html#sum
At last, I would say that someone new to Coq will find answers in
http://adam.chlipala.net/cpdt/
and in
http://www.cis.upenn.edu/~bcpierce/sf/
French/chinese speaking people use http://www.labri.fr/perso/casteran/CoqArt/ but english people have to buy it/go to the library …
All the best,
Pierre B
Le 11 nov. 2012 à 21:52, <kennethadammiller AT gmail.com> a écrit :
> So, after looking at the vector specification at
> http://coq.inria.fr/distrib/V8.4beta/stdlib/Coq.Vectors.VectorDef.html#
> I'm lost as to why t was used in place of vector. Why would the designers
> choose t instead of vector?
> Also, as part of an assignment, I have to model some C unions in Coq-I'm new
> to Coq, so I was wondering what data type I would use to get this done.
- [Coq-Club] Coq data types, kennethadammiller, 11/11/2012
- Re: [Coq-Club] Coq data types, Justus Matthiesen, 11/11/2012
- Re: [Coq-Club] Coq data types, Pierre Boutillier, 11/11/2012
- Re: [Coq-Club] Coq data types, Kenneth Adam Miller, 11/12/2012
