- To: Wilayat Khan <wilayatk AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Re: Compiling depended Coq files
- Date: Mon, 12 Nov 2012 09:44:19 -0500
On 11/12/2012 09:12 AM, Wilayat Khan wrote:
Hello
I
have a Coq project with a number of .v files and its corresponding
Makefile. But I dont know how can I create .vo file for every other
file using this Makefile. Some one suggested me, I used the following
command: (myproject contains files x1.v, ...xn.v, and Makefile)
C:\myproject>
C:\Coq\bin\make
It
creates .v.d files for every file with 0KB size (I was expecting .vo or
.glob files), and with errors at command prompt. According to the
author of the project, Makefile and other files are correct and he has
used Coq 8.3. I am using the same version. Assuming this, I think there
is some problem with the way I am creating .vo files. I would
appreciated, if some one help me and tell me command with complete
path. Am sorry if this is not the right forum for posting such message,
please suggest me one.
You seem to have received a strange suggestion. 'make' is a standard UNIX utility you should install. It is very unlikely that you received it as part of the Coq distribution. |
- [Coq-Club] Compiling depended Coq files, Wilayat Khan, 11/09/2012
- Re: [Coq-Club] Compiling depended Coq files, Pierre Courtieu, 11/12/2012
- Re: [Coq-Club] Compiling depended Coq files, Adam Chlipala, 11/12/2012
- [Coq-Club] Re: Compiling depended Coq files, Wilayat Khan, 11/12/2012
- Re: [Coq-Club] Re: Compiling depended Coq files, Adam Chlipala, 11/12/2012
- Re: [Coq-Club] Compiling depended Coq files, Hendrik Tews, 11/12/2012
