coq-club - [Coq-Club] Announce: Agda 2.3.2
  • To: Agda List <agda AT lists.chalmers.se>, Coq-Club Club <coq-club AT inria.fr>, haskell AT haskell.org
  • Subject: [Coq-Club] Announce: Agda 2.3.2
  • Date: Tue, 13 Nov 2012 01:00:40 +0100
I am pleased to announce the source release of Agda 2.3.2!
http://wiki.portal.chalmers.se/agda/pmwiki.php?n=Main.Download
If you have a recent Haskell Platform installed, you can get it with
cabal update
cabal install Agda
agda-mode setup
agda-mode compile
(The last step is optional.)
Highlights from the release-notes:
http://wiki.portal.chalmers.se/agda/uploads/Main.Download/release-notes-2-3-2.txt
* A new backend that produces highlighted LaTeX from a literate agda file.
* Improved Emacs interaction mode:
- No longer depends on GHCi.
- Syntax highlighting is updated while buffer is type-checked.
- You can case split on several variables simultaneously.
* Syntax extensions:
- Pattern synonyms.
- Qualified mixfix operators.
- Sections and instantiated module imports.
* Enhancements of the type checker:
- Improved coverage checking.
- Improved constraint solving and instance search.
Enjoy,
Andreas (for the Agda team)
Andreas Abel <>< Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
http://www2.tcs.ifi.lmu.de/~abel/
  • [Coq-Club] Announce: Agda 2.3.2, Andreas Abel, 11/13/2012
