- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Infinitely often and not finitely often
- Date: Wed, 14 Nov 2012 22:19:14 +0100
Am 14.11.2012 13:15, schrieb xavier:
Here are two basic definitions I have given to myself:In classical logic,
Definition InfinitelyTrue (P:nat->Prop) := forall n:nat, exists m:nat, (m>n /\
P(m)).
Definition FinitelyTrue (P:nat->Prop) := exists n:nat, forall m:nat, (m>=n ->
~ P(m)).
~(m>n /\ P m)
~(m > n) \/ ~ P m
m > n -> ~ P m.
not (m >= n).
Kind regards, Jonas
The first definition says that the predicate P is true for infinitely many
integers. The way of specifying this is asserting that for any integers,
there's a greater one that has the property.
The second one says the opposite, namely that for some integer, all bigger
ones do not have the property.
I'm trying to prove that one is equivalent to the opposite of the other.
The first direction is easy and the proof need not be told.
Goal forall (P:nat->Prop), InfinitelyTrue P -> ~ FinitelyTrue P.
But I'm stuck on the other direction:
Goal forall (P:nat->Prop), (~ FinitelyTrue P) -> InfinitelyTrue P.
I think that asserting that P is decidable may help, so I'm actually trying to
prove:
Goal forall (P:nat->Prop), decidable P -> ((~ FinitelyTrue P) ->
InfinitelyTrue P).
with decidable defined as follow:
Definition decidable (P:nat->Prop) := forall n:nat, (P n) \/ ~ (P n).
After a few trivial simple steps, I get the following goal:
P : nat -> Prop
dec : forall n : nat, P n \/ ~ P n
n : nat
nft : ~ (forall m : nat, m >= n -> ~ P m)
______________________________________(1/1)
exists m : nat, m > n /\ P m
This looks rather trivial to me. If it is not the case that all m greater than
n do not have the property, then I can find one that has for which it holds.
And yet I'm stuck.
N.B. I don't feel very comfortable with respect to the inequalities (strict
vs. not strict). I have to use le in the definition of FinitelyTrue so as to
allow properties that are true 0 times. And I have to use lt in the definiton
of InfinitelyTrue, or the definition won't match its meaning. And yet, nft
will be true if P n and m=n and ~ P m for all m>n, so there's is something
wrong here.
- [Coq-Club] Infinitely often and not finitely often, xavier, 11/14/2012
- Re: [Coq-Club] Infinitely often and not finitely often, Adam Chlipala, 11/14/2012
- Re: [Coq-Club] Infinitely often and not finitely often, AUGER Cédric, 11/14/2012
- Re: [Coq-Club] Infinitely often and not finitely often, Nils Anders Danielsson, 11/14/2012
- Re: [Coq-Club] Infinitely often and not finitely often, Jonas Oberhauser, 11/14/2012
