- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Dominic Mulligan <dominic.p.mulligan AT googlemail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Surprising type inference failure
- Date: Fri, 16 Nov 2012 12:08:58 +0100
You've hit a tricky specificity of Coq.
Here is a fixed version of your code:
Require Import Arith.
Open Scope nat_scope.
Definition test : nat :=
let f x_y :=
let '(x, y) := x_y in
x + y + 2
in
f (3, 4).
let f x_y :=
x + y + 2
in
f (3, 4).
It typechecks as expected. Can you spot the difference. It's subtle.
Still cannot see it? It's an apostrophe juste after the let.
Not for the explaining: the let pattern := … in … construct has two forms. The historic one, let (x1,…,xn) := e in …, in this form e can be any type with a single constructor with n arguments. That's the form you used (and doesn't do what you expect). The more recent form, is let ' pattern := e in …, in this form you write a pattern with constructors, possible nesting, and as long as this pattern is irrefutable it typechecks (in particular it participates to type inference).
On 16 November 2012 11:24, Dominic Mulligan <dominic.p.mulligan AT googlemail.com> wrote:
Hi,
We're writing an extraction tool targeting Coq theories here from a DSL
for hardware descriptions, and came across a surprising (to me, at least
--- though I don't know Coq that well) type inference failure in the
following Coq code:
let f x_y :=
let (x, y) := x_y in
x + y + 2
in
f (3, 4).
Coq (v8.4, October 2012) complains here that it cannot infer the type of
x_y in the let-binding. But why? I have given Coq everything that it
needs to know that x_y is of type (nat * nat) here. Can anybody explain
why inference is failing, and give any sort of heuristic guidance as to
when type annotations are necessary (short of putting them everywhere
--- I had hoped to try to keep them to a minimum)?
Thanks for any help.
Dominic
- [Coq-Club] Surprising type inference failure, Dominic Mulligan, 11/16/2012
- Re: [Coq-Club] Surprising type inference failure, Arnaud Spiwack, 11/16/2012
- Re: [Coq-Club] Surprising type inference failure, AUGER Cédric, 11/16/2012
