coq-club - [Coq-Club] Unknown exception in Scheme Equality command
  • From: Dominic Mulligan <dominic.p.mulligan AT googlemail.com>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Unknown exception in Scheme Equality command
  • Date: Mon, 19 Nov 2012 10:59:46 +0000
Hi,
I've come across an "Error: unknown exception during scheme creation"
message when trying to automatically derive a decidable equality
function for an inductive data type in Coq v8.4. The data type:
Inductive t : Type := C1 : t | C2 : nat -> t.
Scheme Equality for t.
extracts t_beq fine. However, the following:
Definition num := nat.
Inductive t : Type := C1 : t | C2 : num -> t.
produces the unknown exception. Is this an intended limitation of the
decidable equality generation, where the types of constructors must be
in a normal form? Or is this a bug (in either case a better error
message should be provided, presumably)?
Thanks,
Dom
  • [Coq-Club] Unknown exception in Scheme Equality command, Dominic Mulligan, 11/19/2012
