- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: AUGER Cédric <sedrikov AT gmail.com>
- Cc: Gert Smolka <smolka AT ps.uni-saarland.de>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] functional induction, Equations plugin
- Date: Mon, 26 Nov 2012 18:30:03 +0100
2012/11/26 AUGER Cédric
<sedrikov AT gmail.com>:
> Le Mon, 26 Nov 2012 14:50:02 +0100,
> Pierre Courtieu
> a écrit :
>> Hi Cédric, can you give an example where "induction t" does what you
>> want (t being a non variable term) and "remember x as t ; induction x"
>> doesn't?
> I guess you mean "remember t as x ; induction x."
Yes
> Almost everywhere, I never want to have my environments polluted by
> needless equalities. Plus the generated proof term will be horrible,
> and it has an impact on performances when doing big developpements.
As my proposition is to "remember" only for non variable terms, I understand
that you often use "induction t" with a non variable t. This is interesting,
why
do you need that so often? I never do.
>> Actually if you really want to just apply the induction principle,
>> then "elim" is probably better because "induction" does a lot of other
>> things anyway (what I propose is just doing a bit more for induction).
> A LOT of other things? Well beside generalizing all hypothesis relying
> on the pattern on which induction is done, and then reintroducing them
> in the environment, I do not see what this 'lot' is.
I mean this. On each subgoal, the hypothesis are re-introduced at their
previous place. On big proofs (lots of cases + big environment) this is a bit
expensive and introduces extra beta redexes.
> I have never used
> elim, since I never understood really what it is used for. 'case' and
> 'destruct' do all what I need when dealing with non recursive stuff.
> With recursion, I either use 'fix' (when I want full control, or when I
> use 'Unset Elimination Schemes.') or induction (after having carefuly
> selected what I want to be generalized).
elim x is exaclty "pattern x; apply foo_ind.". It does not generate any name,
it does not generalize any hypothesis (you will need to generalize/intro by
yourself as for case).
OK fix is even lighter...
Anyway I just saw the documentation of the experimental tactic
"dependent induction"
(http://coq.inria.fr/coq/refman/Reference-Manual011.html#@tactic97) which
seems to do exactly what I proposed.
P.
- Re: [Coq-Club] functional induction, Equations plugin, (continued)
- Re: [Coq-Club] functional induction, Equations plugin, Jonas Oberhauser, 11/25/2012
- Re: [Coq-Club] functional induction, Equations plugin, Julien Forest, 11/25/2012
- Re: [Coq-Club] functional induction, Equations plugin, Gert Smolka, 11/25/2012
- Re: [Coq-Club] functional induction, Equations plugin, Matthieu Sozeau, 11/25/2012
- Message not available
- Re: [Coq-Club] functional induction, Equations plugin, Gert Smolka, 11/26/2012
- Re: [Coq-Club] functional induction, Equations plugin, AUGER Cédric, 11/26/2012
- Re: [Coq-Club] functional induction, Equations plugin, Pierre Courtieu, 11/26/2012
- Re: [Coq-Club] functional induction, Equations plugin, Pierre Courtieu, 11/27/2012
