coq-club - [Coq-Club] Scheme Extraction
  • From: Gregory Malecha <gmalecha AT eecs.harvard.edu>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Scheme Extraction
  • Date: Wed, 5 Dec 2012 23:46:13 -0500
Hi --
I'm wondering if anyone knows what could cause this bug when extracting the following code to Scheme:
Set Implicit Arguments.
Set Strict Implicit.
Record Monoid (S : Type) : Type :=
{ monoid_unit : S
Class MonadWriter (T : Type) (M : Monoid T) (m : Type -> Type) : Type :=
{ tell : T -> m unit
; listen : forall {A}, m A -> m (A * T)%type
Section ReaderType.
  Variable S : Type.
  Variable m : Type -> Type.
  Record readerT (t : Type) : Type := mkReaderT
  { runReaderT : S -> m t }.
  Global Instance MonadWriter_readerT T (Mon : Monoid T) (MW : MonadWriter Mon m) : MonadWriter Mon readerT :=
  { tell := fun v => mkReaderT (fun _ => tell v)
  ; listen := fun _ c => mkReaderT (fun s => listen (runReaderT c s))
End ReaderType.
Extraction Language Scheme.
Recursive Extraction MonadWriter_readerT.
Results in:
;; This extracted scheme code relies on some additional macros
(load "macros_extr.scm")
(define __ (lambda (_) __))
(define tell (lambdas (m monadWriter)
  (match monadWriter
     ((Build_MonadWriter tell0 listen0) tell0))))
(define listen (lambdas (m monadWriter x)
  (match monadWriter
     ((Build_MonadWriter tell0 listen0) (@ listen0 __ x)))))
(define runReaderT (lambda (r) r))
(define monadWriter_readerT (lambdas (mon mW) `(Build_MonadWriter
  ,(lambdas (v x) (@ tell (error "Proj Args") mW v)) ,(lambdas (_ c s)
  (@ listen mon mW (@ runReaderT c s))))))
Note the "(error "Proj Args")" which corresponds to a bug. Does anyone know what would cause this or how to fix it?
Thank you.
gregory malecha
http://www.people.fas.harvard.edu/~gmalecha/
