coq-club - Re: [Coq-Club] Unable to do "induction ... eqn:.."
  • From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
  • To: Vincent BENAYOUN <benayoun.vincent AT gmail.com>
  • Cc: Greg Morrisett <greg AT eecs.harvard.edu>, Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>, Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Unable to do "induction ... eqn:.."
  • Date: Sat, 08 Dec 2012 13:40:31 +0100
Notice that "dependent destruction" silently assumes the "JMeq_eq" axiom. This lemma can also be proven without axioms by using an appropriate return clause in your match.
Require Import Program.
Inductive t2 : nat -> Prop :=
| A2 : t2 0
| B2 : t2 1.
Lemma toto2 : forall (x:t2 0), x = A2.
Proof.
dependent destruction x ; auto.
Qed.
Print Assumptions toto2.
(* Axioms: JMeq_eq *)
Lemma toto2_alt : forall (x:t2 0), x = A2.
Proof.
exact (fun x =>
match x as x' in t2 n return
match n with
| 0 => fun x' => x' = A2
| S _ => fun _ => True
end x'
with A2 => eq_refl | B2 => I end).
Qed.
Print Assumptions toto2_alt.
(* Closed under the global context *)
On 12/06/2012 12:29 PM, Vincent BENAYOUN wrote:
Thank you Greg for your answer.
Vincent
2012/12/3 Greg Morrisett
<mailto:greg AT eecs.harvard.edu>>
The easiest thing is to use "dependent destruction" from the
Program library:
| A2 : t2 0
| B2 : t2 1.
Proof.
Qed.
-Greg
On Dec 3, 2012, at 8:41 AM, Vincent BENAYOUN
<mailto:benayoun.vincent AT gmail.com>>
wrote:
> Thank you very much for your answer.
> I understand the error message but I still can't find a way to
solve my problem.
> Thanks to your explanations, I managed to explain more precisely
my problem as follow.
> For the following Lemma, I would like to prove it by induction
but I can't because of the type error. Well, a can give a proof term.
> Inductive t : nat -> Prop :=
> | A : t 0.
> Lemma toto : forall (x:t 0), x = A.
> Proof.
> intro x.
> apply(match x with | A => eq_refl end).
> Qed.
> But since there are many cases, I don't know how to prove the
Lemma. The following Coq script fails with a type error.
> | A2 : t2 0
> | B2 : t2 1.
> Proof.
> intros x.
> eapply(match x with | A2 => eq_refl | B2 => _ end).
> Qed.
> I should prove False in the second branch of the pattern-matching
but I don't know how !
> Is there a way to prove such a Lemma ?
> Thanks in advance,
> Vincent
> 2012/11/29 Arnaud Spiwack
<mailto:aspiwack AT lix.polytechnique.fr>>
> Well, the problem is as explained in the error message: it
produces a type error.
> First note that induction x eqn:e can be broken down into
remember x eqn:e; induction x.
> Rewriting your file as
> Inductive bbb : nat -> Prop :=
> | BBB : bbb 0.
> Lemma bbb_theorem :
> forall (n:nat), bbb n -> n = 0.
> Proof.
> intros n HHH.
> remember HHH eqn:toto.
> induction HHH.
> reflexivity.
> Qed.
> Before the induction step we have the following goal:
> n : nat
> HHH : bbb n
> b : bbb n
> toto : b = HHH
> ______________________________________(1/1)
> n = 0
> Now, doing induction on HHH tries to create the term:
> fun n' : nat => forall b : bbb n', b = HHH -> n' = 0
> The "fun n' =>" part is to be able to substitute n with the
correct value for the required constructor. It also puts toto back
as an implication (you can do it with: revert toto). The problem
here is obvious: b has type bbb n' and HHH has type bbb n which are
different, hence b=HHH isn't well-typed. And the tactic fails.
> Instead you can do elim HHH, which works like induction HHH but
without doing any revert. But of course, in that case, your
remembered equation will be useless.
> On 28 November 2012 11:55, Vincent BENAYOUN
> | BBB : bbb 0.
> Lemma bbb_theorem :
> Proof.
> intros n HHH.
> induction HHH eqn:toto.
> reflexivity.
> Qed.
