coq-club - Re: [Coq-Club] Name-dependent rewriting failures with [let ... in ...]
  • To: Jason Gross <jasongross9 AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Name-dependent rewriting failures with [let ... in ...]
  • Date: Wed, 19 Dec 2012 19:08:50 +0100
Le Wed, 19 Dec 2012 12:36:09 -0500,
Jason Gross
a écrit :
> Hi,
> Can someone explain to me why it matters whether I name a tactic
> [rew] or [rew'] in the following code (in Coq 8.4):
> Goal forall x y z : Type, x = y -> y = z -> x = z.
> intros.
> let rew' := ( fun H => rewrite H in * ) in
> rew' H0.
> assumption.
> Qed.
> (* success *)
> intros.
> let rew := ( fun H => rewrite H in * ) in
> rew H0. (* Error: Library Coq.Setoids.Setoid has to be required
> first. *) Abort.
> Require Import Setoid.
> intros.
> rew H0. (* Error: Tactic failure:Nothing to rewrite. *)
> Thanks.
> -Jason
The answer is that it is because "rew" already exists as a tactic
notation, and this notation is of higher priority than simple
identifiers. I did not check it, but it seems reasonnable.
Imagine, you define
Notation "f o g" := (fun x => f (g x)) (at level 0).
Then how should "fun (o:Type) (g:o) (f:forall T, T->Type) => f o g"?
It is not the same thing as hiding an identifier like in "let x := … in
let x := … in …".
