- To: "fengsheng" <fsheng1990 AT 163.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to define the devision on nat by using Fixpoint
- Date: Thu, 20 Dec 2012 05:29:05 +0100
Le Thu, 20 Dec 2012 04:17:21 +0100 (CET),
"fengsheng"
a écrit :
> when I wrote a function to convert natural numbers to binary
> numbers,I met a problem:how to take the value of a number half.
Here is a funny solution (should even work with -nois option).
But be warned it is quite smart for a solution (it is written in a
continuation passing style, I believe).
They are uglier solutions which are a lot less smart.
You can also consider not dividing by two (I think it is what is done
in the standard library) that is remove 1 from nat and add one to
positive until nat is O.
You can also use some accumulator:
Fixpoint div2 (m n:nat): nat*bool :=
match n with
| O => (m, false)
| S O => (m, true)
| S (S n) => div2 (S m) n
end.
And then prove that the result of div2 O n is strictly smaller (unless n
is equal to 0) than n, and use it for recursion to build the positive.
Inductive nat : Set := | O : nat
| S : nat -> nat
Inductive positive : Set :=
| xH : positive
| xO : positive -> positive
| xI : positive -> positive
Inductive bool : Set := true | false.
Definition with_div2 {A:Type}
(def : A) (f : bool -> nat -> A) (x : nat) : A :=
(fix with_div2 m n := match m with
| O => def
| S m =>
match n with
| O => f false m
| S x => match x with
| O => f true m
| S n => with_div2 m n
end
end
end) x x.
Fixpoint nat_to_positive (n : nat) : option positive :=
with_div2 None
(fun b n => match nat_to_positive n with
| None => if b then Some xH else None
| Some p => Some ((if b then xI else xO) p)
end) n.
Eval compute in nat_to_positive (S (S (S O))).
- [Coq-Club] How to define the devision on nat by using Fixpoint, fengsheng, 12/20/2012
- Re: [Coq-Club] How to define the devision on nat by using Fixpoint, Jason Gross, 12/20/2012
- Re: [Coq-Club] How to define the devision on nat by using Fixpoint, AUGER Cédric, 12/20/2012
- Re: [Coq-Club] How to define the devision on nat by using Fixpoint, Adam Chlipala, 12/20/2012
