coq-club - Re: [Coq-Club] Notation Question
  • To: Hugo Herbelin <Hugo.Herbelin AT inria.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Notation Question
  • Date: Thu, 20 Dec 2012 15:33:54 -0500
Thank you for the response.
The (at level 0, A at level 99) notation was one I tried, but I did not work in my environment either (8.2 .. a bit old) However, it does give different results, in that coqide highlights the colon instead of the ampersand as the location of the parsing error.
(Another quirk was when I tried Print Grammar constr, coqide did not seem to display any useful information, but I just discovered that it was all logged to my terminal window, so that is good to know for next time.)
I don't really need to talk about singletons in the theory I'm working with and the { A , B , .. , C } notation seems to work fine, so I will try that suggestion instead.
On Dec 20, 2012, at 2:59 PM, Hugo Herbelin wrote:
Hi,
If you do "Print Grammar constr", you will see that the notation for
sigT follow the following rule:
| "0" LEFTA
[ "{"; constr:operconstr LEVEL "99"; ":"; constr:operconstr LEVEL "200";
"&"; constr:operconstr LEVEL "200"; "&"; constr:operconstr LEVEL "200";
Because the underlying parser of Coq, which is camlp4/camlp5, is
basically an LL parser, rules have to be factorized by hand.
To get this factorization, you need to put any notation starting with
"{" at level 0, and with first expression being parsed at level
99. This gives:
Notation "{ A , .. , B }" := (cons A .. (cons B nil) ..) (at level 0, A at level 99).
This will not hide the notation for sigT but this will break the
notation sumbool though, because "{ A } + { B }" will not be parsed
any longer as a sumbool but as some "+" of singleton lists "{A}" and
"{B}". So maybe, you would prefer to use the notation:
Notation "{ A , B , .. , C }" := (cons A (cons B .. (cons C nil) ..)) (at level 0, A at level 99).
and to write differently the lists of one element.
Note that it might be wise to set the parsing level for B at 99 too,
depending on whether interferences are likely to happen with other
notations involving ",".
Hope this helps.
Hugo Herbelin
On Thu, Dec 20, 2012 at 02:29:56PM -0500, Gregory Bush wrote:
In the following example, is there a modifier I can use when
declaring the notation so it doesn't hide the notation for sigT?
Require Import List.
(* So far so good *)
Check {x : nat & {y | x < y}}.
Notation "{ A , .. , B }" := (cons A .. (cons B nil) ..).
(* Oops *)
