- To: Daniel de Rauglaudre <daniel.de_rauglaudre AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] classical logic and decidability
- Date: Wed, 26 Dec 2012 11:39:38 +0100
Le Wed, 26 Dec 2012 07:45:42 +0100,
a écrit :
> Hi,
> Thanks for your explanations about decidability. Very interesting,
> made me think a lot, I think a true definition of decidability in
> Coq should be very complicated, since it implies that we define the
> notion of algorithm, and tutti quanti. I think Bruno Barras' thesis
> (Coq in Coq) contains this.
Well, for decidability, in Coq, we often stick with:
Definition decidable {T:Type} (P:T->Prop) : Prop :=
exists f:(T->bool), forall t, P t <-> f t = true.
Or simply we say that P is decidable if there exists a function f of
type "forall t, {P t}+{~P t}". For instance some (probably a lot) of us
use functions of type "forall a b, {a=b}+{a<>b}". It is an example for
which we can say that "forall a, equality to a is decidable".
Of course, it is a little "impure", as it covers cases involving
oracles, and with classical logic + axiom of choice, I think any
language is decidable.
For the complicateness of this notion involving Turing Machines, I
quickly did the following (92 loc).
I think it covers exactly the definition of decidability.
CoInductive TuringDemiBand : Set :=
| More : bool -> TuringDemiBand -> TuringDemiBand
CoFixpoint demi_bk : TuringDemiBand :=
More false demi_bk
Fixpoint demi_init (l : list bool) : TuringDemiBand :=
match l with
| nil => demi_bk
| cons b l => More b (demi_init l)
end
Record TuringBand : Set := TB
{ past : TuringDemiBand
; current : bool
; future : TuringDemiBand
Definition init (l : list bool) : TuringBand := TB demi_bk false
(demi_init l) .
Fixpoint BoundedSet (n : nat) : Set :=
match n with
| O => Empty_set
| S n => option (BoundedSet n)
end
Inductive State (n : nat) : Set :=
| Final : bool -> State n
| Working : BoundedSet n -> State n
Record Transition (n : nat) : Set := Trans
{ new_state : State n (* None is for final state *)
; go_past : bool
; replace_current : bool
(* I restrict to deterministic Turing Machines, as it does change theory
of complexity but does not affect decidability *)
Definition TransSys (n : nat) := BoundedSet n -> bool -> Transition n
Record TuringMachine : Set := TM
{ states_cardinality : nat
; transitions : TransSys states_cardinality
; initial_state : BoundedSet states_cardinality
Record WStatus (n : nat) : Set := WSt
{ state : BoundedSet n
; band : TuringBand
Inductive Status (n : nat) : Set :=
| Running : WStatus n -> Status n
| Terminal : bool -> Status n
Definition app_trans (n : nat) (t : TransSys n) (s : WStatus n) :
Status n := let t := t (state n s) (current (band n s)) in
match new_state n t with
| Final b => Terminal n b
| Working ns =>
let b := if go_past n t
then let (b, db) := past (band n s) in
TB db b (More (replace_current n t) (future (band n
s))) else let (b, db) := future (band n s) in
TB (More (replace_current n t) (past (band n s))) b db
in Running n {| state := ns ; band := b |}
end
Inductive EndsWith
(*true parameters*) (n : nat) (t : TransSys n) (r : bool)
(*false parameter*) (b : WStatus n) : Prop :=
| Halt : app_trans n t b = Terminal n r -> EndsWith n t r b
| Continue : forall ws, app_trans n t b = Running n ws ->
EndsWith n t r ws -> EndsWith n t r b
Record Encoding (T : Type) := Enc
{ encode : T -> list bool
; decode : list bool -> T
; code_spe : forall (t : T), decode (encode t) = t
Definition Language (T : Type) := T -> Prop
Record Decidable (T : Type) (L : Language T) : Prop :=
{ decider : TuringMachine
; coder : Encoding T
; decision : forall t, (L t) <->
EndsWith (states_cardinality decider) (transitions
decider) true (WSt _ (initial_state decider) (init (encode T coder t)))
- [Coq-Club] classical logic and decidability, Daniel de Rauglaudre, 12/21/2012
- Re: [Coq-Club] classical logic and decidability, Adam Chlipala, 12/21/2012
- Re: [Coq-Club] classical logic and decidability, Pierre Courtieu, 12/21/2012
- Re: [Coq-Club] classical logic and decidability, Jean Goubault-Larrecq, 12/21/2012
- Re: [Coq-Club] classical logic and decidability, Daniel de Rauglaudre, 12/26/2012
- Re: [Coq-Club] classical logic and decidability, AUGER Cédric, 12/26/2012
- Re: [Coq-Club] classical logic and decidability, AUGER Cédric, 12/21/2012
