coq-club - Re: [Coq-Club] A false hope: A thing which cannot be directly expressed in Coq
  • From: Kristopher Micinski <krismicinski AT gmail.com>
  • To: Victor Porton <porton AT narod.ru>
  • Cc: coq club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] A false hope: A thing which cannot be directly expressed in Coq
  • Date: Sat, 29 Dec 2012 12:48:09 -0500
I agree with Adam, and to add to the confusion I believe relying on the heuristics will lead to problems between versions. Adam's suggestion to specify everything personally helps me read other people's developments as well, if a bit cumbersome. (and yet you can read about the heuristics in the manual)
Kris
On Dec 29, 2012 12:36 PM, "Victor Porton" <porton AT narod.ru> wrote:
You may call me a troll again, but it seems for me that I've found a deficiency of Coq which should be addressed in future proof assistants. (Correct me if there is a way to write this in Coq which I miss.)
Previously I though that this can be expressed with implicit type inference in Coq, but my experiments with CoqIDE don't show a way to do this.
Let f in Hom(A;B), g in Hom(B;C) and h in Hom(A;C) for some category.
Let also every Hom(X;Y) is a complete lattice with least element 0.
Consider this formula:
(g o f) /\ h = 0
(where /\ denotes lattice meet).
Intuitively this formula is clear. It expresses an equality for arbitrary objects A, B, C.
But when we write it explicitly, we need to add before it:
forall A, B, C, f in Hom(A;B), g in Hom(B;C), h in Hom(A;C).
This is cumbersome as possibly objects for f, g, h can be inferred from the formula itself (which intuitively implies that f and g have the same source and destination, that the source of h is the same as the source of f etc.) and to specify it explicitly is too cumbersome.
At least we would shorten this formula to
forall f, g, h.
But how to denote this? (both in informal mathematics and in formal one)
I've written a book (informal math) where these things are expressed with explicit quantification in order not to introduce a non-standard logic which allows such expressions without explicit quantifiers. This is bad.
Victor Porton - http://portonvictor.org
