- From: Gabriel Scherer <gabriel.scherer AT gmail.com>
- To: Kristopher Micinski <krismicinski AT gmail.com>
- Cc: Victor Porton <porton AT narod.ru>, coq club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Using setoids or not?
- Date: Sat, 29 Dec 2012 21:03:18 +0100
The formalization of Relation pointed to here does not explicitly use
setoids, but implicitly uses a distinct notion of equality/equivalence
from Coq's native equality (which might be unnecessary with function
eta-equality added in 8.4) when it formulates theorems such as the
following one in terms of equivalence:
Theorem rtc_rsc_coincide :
forall (X:Type) (R: relation X) (x y : X),
clos_refl_trans R x y <-> refl_step_closure R x y.
What is really being meant here is
forall X (R : Relation X), equiv_rel (clos_refl_trans R)
(refl_step_closure R).
for the obvious notion of relation equivalence, equipped with which
relations form a setoid.
On Sat, Dec 29, 2012 at 8:57 PM, Kristopher Micinski
wrote:
> Basically, whenever you start running into problems with coq's intensional
> equality. Coq makes the trade off of intensional equality for decidable type
> checking, but there are always sticky situations where you need more
> elaborate representations, hence setoids.
> On Dec 29, 2012 2:49 PM, "Victor Porton"
> wrote:
>> http://www.cs.berkeley.edu/~megacz/coq-categories/ uses setoids.
>> http://www.seas.upenn.edu/~cis500/current/sf/Rel.v does not use setoids.
>> Why these are different with their basic underlining data types?
>> In which cases setoids should be used and in which not?
>> Victor Porton - http://portonvictor.org
- [Coq-Club] Using setoids or not?, Victor Porton, 12/29/2012
- Re: [Coq-Club] Using setoids or not?, Kristopher Micinski, 12/29/2012
- Re: [Coq-Club] Using setoids or not?, Gabriel Scherer, 12/29/2012
