- To: Andrew Hirsch <akhirsch AT gwmail.gwu.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Error with Ltac
- Date: Mon, 31 Dec 2012 17:16:56 -0500
That code parses fine for me in Coq 8.4pl1. Perhaps you have some unfortunate notation loaded which is interfering with Coq's built-in parsing rules. Do you get the same error message entering this code in a fresh file or coqtop session?
On 12/31/2012 04:39 PM, Andrew Hirsch wrote:
I've been playing with some Ltac recently, but I've not been able to get Coq to except it: when I try this piece of Ltac from Adam Chilpala's book, I get this error:
Code:
Ltac my_tauto :=
repeat match goal with
| [ H : ?P |- ?P ] => exact H
| [ |- True ] => constructor
| [ |- _ /\ _ ] => constructor
| [ |- _ -> _ ] => intro
| [ H : False |- _ ] => destruct H
| [ H : _ /\ _ |- _ ] => destruct H
| [ H : _ \/ _ |- _ ] => destruct H
| [ H1 : ?P -> ?Q, H2 : ?P |- _ ] => specialize (H1 H2)
end.
Error:
Toplevel input, characters 90-91:
Syntax error: ',' or '|-' expected (in [match_context_rule]).
Which is right over the first closing bracket.
It works fine if I don't try to match hypotheses, but the moment I do, I get this error.
Any ideas?
- [Coq-Club] Error with Ltac, Andrew Hirsch, 12/31/2012
- Re: [Coq-Club] Error with Ltac, Adam Chlipala, 12/31/2012
