- From: Alan Schmitt <alan.schmitt AT polytechnique.org>
- To: "coq-club Club" <coq-club AT inria.fr>
- Subject: [Coq-Club] html coqdoc does not generate some files?
- Date: Fri, 04 Jan 2013 11:32:57 +0100
Hello,
I just noticed I had many broken links on my site that come from using
coqdoc with html output. More precisery, when I run
coqdoc -toc -html -d html *.v
I get an html file for each of the .v files, as well as a toc.html and
index.html. In the later, I have a lot of links of the form:
<a href="agent.html#agent">agent</a> [inductive, in <a
href="agent.html">agent</a>]<br/>
but no file "agent.html" was generated.
There is an agent target defined in one of the files:
HOC02DefLTS.html:<span class="id" type="keyword">Inductive</span> <a
name="agent"><span class="id" type="inductive">agent</span></a> : <span
class="id" type="keyword">Set</span> :=<br/>
but the file name is not correctly set in index.html.
Is it a (known) bug?
Thanks,
Alan
- [Coq-Club] html coqdoc does not generate some files?, Alan Schmitt, 01/04/2013
- Re: [Coq-Club] html coqdoc does not generate some files?, Hugo Herbelin, 01/04/2013
- Re: [Coq-Club] html coqdoc does not generate some files?, Alan Schmitt, 01/04/2013
