coq-club - Re: [Coq-Club] Are these provable?
  • To: Andrew Hirsch <akhirsch AT gwmail.gwu.edu>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Are these provable?
  • Date: Wed, 09 Jan 2013 16:49:34 -0500
On 01/09/2013 04:45 PM, Andrew Hirsch wrote:
I have a couple of lemmas about the standard Coq library I would like
to be able to use in a project. However, I can't find a proof of
either, and it seems that there isn't one in the standard libraries.
The first is about Sigma types. I want to prove that:
forall (A : Set) (Q : A -> Prop) (b : {a : A | Q a}), b = exist Q
(proj1_sig b) (proj2_sig b).
This looks like it could be proved by [destruct b; reflexivity].
With this decision procedure:
Definition var_eq : forall (a b : var), {a = b} + {a<> b}.
I want to then prove:
forall (x : var) (A : Set) (a b : A), (if var_dec x x then a else b) = a.
The decision procedure implementation doesn't matter. You can do [intros; destruct (var_dec x x); tauto], which follows just from the _type_ of the procedure.
