coq-club - [Coq-Club] SCP Special Issue on Invariant Generation - Final Call for Papers [1 month to go]
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] SCP Special Issue on Invariant Generation - Final Call for Papers [1 month to go]
  • Date: Fri, 11 Jan 2013 09:09:04 +0000
(Apologies if you receive multiple copies of this announcement)
Science of Computer Programming
-- FINAL CALL FOR PAPERS [1 month to go] --
This special issue is devoted to the 4th international Workshop on
Invariant Generation (WING 2012)
http://cs.nyu.edu/acsys/wing2012/
which was held on June 30 2012 in Manchester as a satellite event of
IJCAR 2012. The scope of the workshop is the automation of extracting
and synthesising auxiliary properties of programs, in particular
providing, debugging, and verifying auxiliary invariant annotations.
This should be seen in a broad sense and relevant topics include (but
are not limited to) the following:
* Program analysis and verification
* Inductive assertion generation
* Inductive proofs for reasoning about loops
* Applications to assertion generation using:
- abstract interpretation,
- static analysis,
- model checking,
- theorem proving,
- theory formation,
- algebraic techniques
* Tools for inductive assertion generation and verification
* Alternative techniques for reasoning about loops
Submission to this special issue is completely open. We expect
original articles (typically not more than 30 pages) that present
high-quality contributions and must not be simultaneously submitted
for publication elsewhere. Submission of extended versions of
previously published papers is possible as long as the extension is
significant, i.e., the submission can be considered a new paper, the
previous paper is referenced, and the new material is clearly marked.
Submissions must comply with SCP's author guidelines
http://www.elsevier.com/wps/find/journaldescription.cws_home/505623/authorinstructions
and be written in English. Submission is over the SCP website:
http://ees.elsevier.com/scico/default.asp
which you will have to register for if you do not have an account.
When submitting your paper please choose the article type "Special issue:
WING 2012".
IMPORTANT DATES
* Submission of papers: February 11, 2013.
* Notification: April 26, 2013.
GUEST EDITORS
* Gudmund Grov (Heriot-Watt University, UK)
* Thomas Wies (New York University, USA)
CONTACT
Please send any queries you may have to:
wing2012 AT easychair.org
  • [Coq-Club] SCP Special Issue on Invariant Generation - Final Call for Papers [1 month to go], Gudmund Grov, 01/11/2013
