- To: Gregory Malecha <gmalecha AT eecs.harvard.edu>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Problem Compiling Coq
- Date: Wed, 16 Jan 2013 22:59:13 +0100
Hi,
Compilation with camlp4 is broken in 8.4 and 8.4pl1. You should apply
revision 16122 from the v8.4 bug-fix branch [1] or use camlp5 instead
(even if Coq generally works with camlp4 as well as it does with
camlp5, strange things happen sometimes in the parser: in particular
the compilation of the reference manual might loop when using camlp4).
Hugo Herbelin
[1]
https://gforge.inria.fr/scm/viewvc.php/branches/v8.4/scripts/coqmktop.ml?root=coq&r1=16015&r2=16122&pathrev=16122)
On Wed, Jan 16, 2013 at 09:12:04PM +0000, Gregory Malecha wrote:
> Hello --
> I have a fresh download of 8.4pl1 which I ran ./configure with no
> arguments and then make, things go along great for a little while and
> then
> I get this error:
> make[1]: Entering directory `/home/gmalecha/devel/coq/coq-8.4pl1'
> CHECK revision
> COQMKTOP -o bin/coqtop.byte
> File "/tmp/coqmain4a488c.ml", line 1:
> Error: Cannot find file q_coqast.cmo
> make[1]: *** [bin/coqtop.byte] Error 2
> make[1]: Leaving directory `/home/gmalecha/devel/coq/coq-8.4pl1'
> make: *** [world] Error 2
> Find does report that it exists:
> $ find . -iname q_coqast.cmo
> ./parsing/q_coqast.cmo
> Any idea what is going wrong or how to fix it? I'm running ocaml 4.00.1
> $ ocamlc -v
> The OCaml compiler, version 4.00.1
> Standard library directory: /usr/lib64/ocaml
> Thanks.
> gregory malecha
> http://www.people.fas.harvard.edu/~gmalecha/
- [Coq-Club] Problem Compiling Coq, Gregory Malecha, 01/16/2013
- Re: [Coq-Club] Problem Compiling Coq, Hugo Herbelin, 01/16/2013
