coq-club - Re: [Coq-Club] Module Inheritance in Coq?
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: bhandalc AT tcd.ie
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Module Inheritance in Coq?
  • Date: Thu, 24 Jan 2013 12:58:51 +0100
Hello, notice that "Include A" allows to include all definitions of
module (type) A in the current module (type).
This not subtyping but often helps to develop modules layer by layer.
see: http://coq.inria.fr/coq/refman/Reference-Manual004.html#@command52
Hope this helps,
Pierre
2013/1/24
<bhandalc AT tcd.ie>:
> Hi,
> I notice that Coq does not allow Module Sub-Typing, which would facilitate
> some really nice inheritance i.e.
> Module Type A
> Module Type B : A
> Right now, all that can be done is:
> Module Type A
> Module B : A
> If I am incorrect please stop me here? If not, read on.
> The above allows B to inherit all the results of A as long as B redefines
> the
> Parameters of A. Redefining the parameters is much like function override in
> OO programming and inheritance. Except in Coq it's enforced. It would be
> nice
> if the parameters didn't HAVE to be redefined. But the real problem is that
> after one step, you can't go any further i.e. it is impossible to then
> write:
> Module C : B
> Because B is not a Module Type, it is just an instance of A. What we would
> like is to define another Module TYPE B which is a subtype of A, just as in
> OO
> programming one can define subclasses of a superclass.
> To summarise, I have two suggestions:
> 1. Allow Module Sub-Typing i.e. inheritance.
> 2. Remove the enforcement of redefining all Parameters, and if they are not
> redefined, just carry them over as they are. (This is less crucial).
> Thoughts anyone?
