- From: Thomas Braibant <thomas.braibant AT gmail.com>
- To: Enrico Tassi <enrico.tassi AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] vm_compute and evars
- Date: Fri, 25 Jan 2013 10:18:40 +0100
I had a quick look at the code of pf_abs_evar, which seems to do the
same kind of transformation as what I implemented (except that what I
did takes some extra steps to fold applications of terms).
Since we now have at least two versions outside of Coq's code of the
same very useful piece of code, I feel it would be cool to push one of
them in the general code :).
Thomas
On Thu, Jan 24, 2013 at 7:41 PM, Enrico Tassi
wrote:
> On Thu, Jan 24, 2013 at 06:38:42PM +0100, Thomas Braibant wrote:
>> The idea is that when you have a term [T] that contains evars, it is
>> possible to transform [T] into a function [F] in which evars have been
>> abstracted, applied to these evars
> The ssreflect plugin does this all over the place, but the main
> motivation is to pass around just a constr (no evar map is needed if the
> term is evar free).
> If you want to give a look, the function is called pf_abs_evars, but it is
> really tricky code.
> Cheers
> Enrico Tassi
- [Coq-Club] vm_compute and evars, Thomas Braibant, 01/24/2013
- Re: [Coq-Club] vm_compute and evars, Chung-Kil Hur, 01/24/2013
- Re: [Coq-Club] vm_compute and evars, Thomas Braibant, 01/24/2013
- Re: [Coq-Club] vm_compute and evars, Chung-Kil Hur, 01/25/2013
- Re: [Coq-Club] vm_compute and evars, Thomas Braibant, 01/25/2013
- Re: [Coq-Club] vm_compute and evars, Enrico Tassi, 01/24/2013
