- To: Dmitry Grebeniuk <gdsfh1 AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] FMapAVL + String key
- Date: Sat, 2 Feb 2013 03:33:29 +0100
I did the following.
I do not know if it is or is not worth to be added in the standard
library or the contribs. I have not documented it, although it is
rather straightforward.
I did use only very low-level tactics. The proofs can be shortened by
using more complex tactics.
Implementing directly a module for Strings would also have been
shorter. I did this to check my statement that a "Serializable" module
would be a good idea. And it seems rather good (at least for strings).
Require Import Utf8.
Require Import Ascii.
Require Import String.
Require Import FMapAVL.
Set Implicit Arguments.
Inductive data : Set := Node : data → data → data | Leaf.
Definition is_leaf (d : data) : Prop :=
match d with Leaf => True | _ => False end.
Definition is_node (d : data) : Prop :=
match d with Leaf => False | _ => True end.
Definition is_leaf_unicity d : ∀ (il1 il2 : is_leaf d), il1 = il2 :=
match d with
| Leaf => λ (il1 il2 : is_leaf Leaf),
match il1, il2 with I, I => eq_refl I end
| Node x y => λ (il1 : is_leaf (Node x y)), match il1 with end
end.
Definition is_node_unicity d : ∀ (il1 il2 : is_node d), il1 = il2 :=
match d with
| Node x y => λ (il1 il2 : is_node (Node x y)),
| Leaf => λ (il1 : is_node Leaf), match il1 with end
end.
Definition dleft d : is_node d → data :=
match d with
| Leaf => λ H, match H with end
| Node l _ => λ _, l
end.
Definition dright d : is_node d → data :=
match d with
| Node _ r => λ _, r
end.
Inductive data_lt (a b : data) : Prop :=
| LtLeaf : is_leaf a → is_node b → data_lt a b
| LtLeft : ∀ Na Nb, data_lt (dleft a Na) (dleft b Nb) → data_lt a b
| LtRight : ∀ Na Nb, dleft a Na = dleft b Nb →
data_lt (dright a Na) (dright b Nb) → data_lt a b.
Definition right_node a b (H : data_lt a b) : is_node b :=
match H with
| LtLeaf _ H => H
| LtLeft _ H _ => H
| LtRight _ H _ _ => H
end.
Fixpoint data_lt_trans x y z (H : data_lt x y) : data_lt y z → data_lt
x z. Proof.
destruct H.
(* case LtLeaf *)
intros K; constructor 1; auto; destruct K; auto.
(* case LtLeft *)
intros K; apply (LtLeft x z Na (right_node K)); destruct K; simpl
in *. exfalso; destruct y; simpl in *; auto.
eapply data_lt_trans; eauto; case (is_node_unicity y Na0 Nb);
auto. case e; case (is_node_unicity y Nb Na0); auto.
(* case LtRight *)
intros K; destruct K.
apply (LtLeft x z Na Nb0); rewrite H; case (is_node_unicity y Na0
Nb); auto. apply (LtRight x z Na Nb0); case H1; case (is_node_unicity y
Nb Na0); auto. eapply data_lt_trans; eauto; case (is_node_unicity y Na0
Nb); auto. Qed.
Lemma data_lt_not_eq x y : data_lt x y → x ≠ y.
Proof.
intros H K; revert H; case K; clear.
revert x; fix 2; intros x [lx nx | nx1 nx2 Hlt | nx1 nx2 Heq Hlt];
destruct x; simpl in *; eauto.
Qed.
Fixpoint data_compare x y : OrderedType.Compare data_lt (@eq data) x y.
refine (
match x with
| Leaf => match y with
| Leaf => OrderedType.EQ _
| Node c d => OrderedType.LT _
end
| Node a b => match y with
| Leaf => OrderedType.GT _
| Node c d => match data_compare a c with
| OrderedType.LT H => OrderedType.LT _
| OrderedType.EQ K =>
match data_compare b d with
| OrderedType.EQ H => OrderedType.EQ _
| OrderedType.GT H => OrderedType.GT _
end
end
end
end
Proof. exact (LtLeft (Node a b) (Node c d) I I H).
Proof. exact (LtRight (Node a b) (Node c d) I I K H).
Proof. exact (match K with eq_refl => match H with eq_refl=>eq_refl _
end end). Proof. exact (LtRight (Node c d) (Node a b) I I (eq_sym K) H).
Proof. exact (LtLeft (Node c d) (Node a b) I I H).
Proof. exact (LtLeaf Leaf (Node a b) I I).
Proof. exact (LtLeaf Leaf (Node c d) I I).
Proof. exact (eq_refl Leaf).
Defined.
Module DataOrder.
Definition t := data.
Definition eq := @eq t.
Definition lt := data_lt.
Definition eq_refl := @eq_refl t.
Definition eq_sym := @eq_sym t.
Definition eq_trans := @eq_trans t.
Definition lt_trans := data_lt_trans.
Definition lt_not_eq := data_lt_not_eq.
Definition compare := data_compare.
Definition eq_dec : ∀ x y : t, {eq x y} + {¬eq x y} :=
λ x y, match compare x y with
| OrderedType.GT H => right (λ K, lt_not_eq H (eq_sym K))
| OrderedType.EQ H => left H
| OrderedType.LT H => right (lt_not_eq H)
end.
End DataOrder.
Module Type Serializable.
Parameter t : Type.
Parameter serialize : t → data.
Parameter unserialize : data → t.
Hypothesis SerializeSection : ∀ t, unserialize (serialize t) = t.
End Serializable.
Module SerializeOrder (S : Serializable).
Definition t := S.t.
Definition lt := λ x y, DataOrder.lt (S.serialize x) (S.serialize y).
Definition lt_trans x y z (H : lt x y) (K : lt y z) :=
DataOrder.lt_trans H K. Lemma lt_not_eq x y (H : lt x y) (Heq : x =
y) : False. Proof. unfold lt in *. apply (DataOrder.lt_not_eq H). case
Heq. split. Qed. Definition compare x y : OrderedType.Compare lt eq x y.
refine (match DataOrder.compare (S.serialize x) (S.serialize y) with
end);
auto.
case (S.SerializeSection x); rewrite H; apply S.SerializeSection.
Defined.
end.
End SerializeOrder.
(********** Example with ASCII ************)
Module SBool.
Definition t := bool.
Definition serialize (b : bool) := if b then Node Leaf Leaf else Leaf.
Definition unserialize (d : data) := if d then true else false.
Lemma SerializeSection : ∀ b, unserialize (serialize b) = b.
intros []; split.
Qed.
End SBool.
Module SAscii.
Definition t := ascii.
Definition serialize a :=
match a with
| Ascii a b c d e f g h => Node (Node (Node (SBool.serialize a)
(SBool.serialize b))
(Node (SBool.serialize c)
(SBool.serialize d)))
(Node (Node (SBool.serialize e)
(SBool.serialize f))
(Node (SBool.serialize g)
(SBool.serialize h)))
end.
Definition unserialize a :=
match a with
| Node (Node (Node a b) (Node c d)) (Node (Node e f) (Node g h)) =>
Ascii (SBool.unserialize a)
(SBool.unserialize b)
(SBool.unserialize c)
(SBool.unserialize d)
(SBool.unserialize e)
(SBool.unserialize f)
(SBool.unserialize g)
(SBool.unserialize h)
| _ => Ascii false false false false false false false false
end.
intros [a b c d e f g h]; simpl; repeat rewrite
SBool.SerializeSection. split.
Qed.
End SAscii.
Module SString.
Definition t := string.
Fixpoint serialize s :=
match s with
| EmptyString => Leaf
| String a s => Node (SAscii.serialize a) (serialize s)
end.
Fixpoint unserialize d :=
match d with
| Leaf => EmptyString
| Node l r => String (SAscii.unserialize l) (unserialize r)
end.
intros b; induction b; simpl; auto.
rewrite SAscii.SerializeSection.
rewrite IHb.
split.
Qed.
End SString.
Module StringOrder := SerializeOrder SString.
Module StringMap := Make StringOrder.
- [Coq-Club] FMapAVL + String key, Dmitry Grebeniuk, 02/01/2013
- Re: [Coq-Club] FMapAVL + String key, AUGER Cédric, 02/02/2013
- Re: [Coq-Club] FMapAVL + String key, Dmitry Grebeniuk, 02/03/2013
- Re: [Coq-Club] FMapAVL + String key, AUGER Cédric, 02/03/2013
- Re: [Coq-Club] FMapAVL + String key, Dmitry Grebeniuk, 02/07/2013
- Re: [Coq-Club] FMapAVL + String key, AUGER Cédric, 02/07/2013
- Re: [Coq-Club] FMapAVL + String key, Marco Maggesi, 02/08/2013
