coq-club - [Coq-Club] Can one pull a 'let' outside a 'match'?
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Can one pull a 'let' outside a 'match'?
  • Date: Mon, 4 Feb 2013 10:57:09 -0800
Hi,
I'm quite new at Coq; sorry if this is silly or has been covered before.
Suppose I have an Gallina term of the form
   match (let pattern1 := term1 in E) [in ... return ...] with
   | pat1 => v1
   | pat2 => v2
   end
as part of a proof goal, say.  It looks to me like that _expression_ should
be equivalent to
   match E [in ... return ...] with
   | pat1 => v1
   | pat2 => v2
   end
with the proviso that the variables bound in pattern1 in the later case
don't capture anything from the match outside of E due to their larger scope;
i.e. the transformation ought to be OK modulo a possible alpha-conversion.
If that is correct, and I want to rewrite a proof goal according to such
a transformation, how would I go about it in general? Is there a tactic that
does this sort of rewrite of Gallina built-in syntax?
Side note: In my particular case it looks like E would clearly match just one
of the specific patterns (e.g. pat1) and so the _expression_ ought to simplify;
but the first form doesn't simplify, at least not with 'simpl', and I'm assuming
that it is the 'let' _expression_ in the discriminee that is fouling things up...
- Dan
