- From: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Modules and Recursive Extraction
- Date: Thu, 07 Feb 2013 17:36:56 +0100
Hi Coq-Club !
I encountered a strange feature of Recursive Extraction (or Separate Extraction) while working with modules: it seems that, when a member of a module is to be extracted, the whole module is taken as a dependency.
Here is my example (tested in Coq 8.4pl1):
Module M.
Definition g (x:nat) := x.
Definition f (x:nat) := x.
End M.
Recursive Extraction M.f.
It returns:
type nat =
| O
| S of nat
module M =
struct
(** val g : nat -> nat **)
let g x =
x
(** val f : nat -> nat **)
let f x =
x
end
While I do not expect g to be extracted.
Is this a well-known behavior ? Is there any justification for that ? Is it a bug ?
In the same order of ideas, I would not expect a module to be extracted entirely while applied to a functor, but only the elements of the signature. The signatures used in functors parameters could be themselves stripped of unnecessary parts.
Thanks !
- [Coq-Club] Modules and Recursive Extraction, Jacques-Henri Jourdan, 02/07/2013
