coq-club - Re: [Coq-Club] Predicative Church numerals
  • From: Arthur Azevedo de Amorim <arthur.aa AT gmail.com>
  • To: Colm Bhandal <bhandalc AT tcd.ie>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Predicative Church numerals
  • Date: Thu, 14 Feb 2013 09:46:54 -0500
I did try this, but then we run into a problem in a predicative setting. If nat is polymorphic in Type_n, then (nat -> nat) has type Type_{n+1}, so one can't do the application "m (nat -> nat)". Indeed, by defining nat in Prop this works just fine.
On Thu, Feb 14, 2013 at 7:42 AM, Colm Bhandal <bhandalc AT tcd.ie> wrote:
Try this:
Definition next (u : nat) (f : nat -> nat -> nat) (n m : nat) : nat :=
  m (nat -> nat) (f n) u.
Here, u is the right unit of f, f is the lower order function, and n, m are the arguments to the higher order function. So for example:
Definition mult := next 0 plus.
Where 0 := fun X f x => x
Expanded out this is:
fun n m => m (nat -> nat) (plus n) 0.
Not sure if this will work but it's an idea.
On 13 February 2013 20:50, Arthur Azevedo de Amorim <arthur.aa AT gmail.com> wrote:
I was playing a little bit with predicative Church numerals
Definition nat := forall X : Type, (X -> X) -> X -> X.
Some functions are easy to define...
Definition plus (n m : nat) : nat :=
  fun X f x => n X f (m X f x).
Definition mult (n m : nat) : nat :=
  fun X f x => n X (m X f) x.
Definition exp (n m : nat) : nat :=
  fun X f x => m (X -> X) (n X) f x.
... However, when trying to go one level up and code a tower of exponentials, I got stuck. Can it be done at all with a predicative encoding?
