coq-club - Re: [Coq-Club] Getting [Existing Class] to behave like [Class]
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: Jason Gross <jasongross9 AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Getting [Existing Class] to behave like [Class]
  • Date: Tue, 19 Feb 2013 11:20:27 +0100
On 19 févr. 2013, at 06:44, Jason Gross
wrote:
> Hi,
> Is there a way to make [Existing Class] behave like [Class]? For example,
> in the following code, if I have [Existing Class IsCat], then [rewrite
> Associativity] generates an extra goal [IsCat C]; but if I define [IsCat]
> to be a [Class] to start off with, then this goal does not show up.
> Set Implicit Arguments.
> Record Cat :=
> Object :> Type;
> Morphism : Object -> Object -> Type;
> Compose : forall {s d d'}, Morphism d d' -> Morphism s d -> Morphism s
> d'
> Record IsCat (C : Cat) :=
> Associativity : forall o1 o2 o3 o4
> (m1 : Morphism C o1 o2)
> (m2 : Morphism C o2 o3)
> (m3 : Morphism C o3 o4),
> Compose C (Compose C m3 m2) m1 = Compose C m3
> (Compose C m2 m1)
> Existing Class IsCat.
> Section foo.
> Variable C : Cat.
> Context `(IsCat C).
> Lemma foo o1 o2 o3 o4
> : Compose C (Compose C m3 m2) m1 = Compose C (Compose C m3 m2) m1.
> rewrite Associativity.
Hi Jason,
This is because the IsCat record is not declared implicit for Associativity.
Using this setting of implicts works:
Arguments Associativity {C} {IsCat} {o1 o2 o3 o4} m1 m2 m3 : rename.
-- Matthieu
