coq-club - [Coq-Club] Abstracting leads to a term ill-typed… yet well-typed
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Abstracting leads to a term ill-typed… yet well-typed
  • Date: Fri, 15 Feb 2013 17:10:35 -0800
Hello Coq-club,
I posted this on StackOverflow but it seems to reach only a very limited audience, so this might be a better place.
cf. http://stackoverflow.com/questions/14867685/abstracting-leads-to-a-term-ill-typed-yet-well-typed
--- (I hope this renders well...)
I was stuck on a problem for a while, for which I derived a smaller standalone example:
Axiom f : nat -> Set.
Goal forall (n : nat) (e : n = n) (x : f n),
  match e in _ = _n return f _n -> Prop with
  | Logic.eq_refl => fun v : f n => v = x
  end x.
Now, if you try to destruct e, you get the following error message:
Error: Abstracting over the terms "n0" and "e" leads to a term
"fun (n0 : nat) (e : n0 = n0) =>
 forall x : f n0,
 match e in (_ = _n) return (f _n -> Prop) with
 | Logic.eq_refl => fun v : f n0 => v = x
 end x" which is ill-typed.
After scratching my head for a while, I couldn't figure out what was ill-typed in that term... So I tried this:
Definition illt :=
  fun (n : nat) (e : n = n) =>
  forall x : f n,
  end x.
And Coq accepts it, at type forall n : nat, n = n -> Prop.
So, what is wrong with this error message, and how could I solve/tweak my initial goal?
Here is the Set Printing All versions of the error message:
"fun (n0 : nat) (e : @eq nat n0 n0) =>
 forall x : f n0,
 match e in (@eq _ _ _n) return (f _n -> Prop) with
 | eq_refl => fun v : f n0 => @eq (f n0) v x
It seems to be a well-typed term, and nothing is implicit.
Thank you,
- Valentin
