- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] nested definitions
- Date: Thu, 21 Feb 2013 23:04:15 +0100
Hello.
A few months ago I asked about decidable equality on nested structures. As usual, Cedric Auger came to the rescue :)
Here's the log about the thread in question: https://sympa.inria.fr/sympa/arc/coq-club/2012-08/msg00122.html
Anyway, I believe i have a similar problem now, but I'm not sure how I could adapt the approach to solve my particular situation.
Say you have an inductive like so:
Inductive box : Type :=
Cons : nat -> list box -> box.
And now I want to prove
Lemma p_dec:
forall b:box, p b \/ ~ p b.
where p is some predicate of the following shape:
Inductive p (b:box) : Prop :=
| Xyz : forall n lb, b = Cons n lb ->
(forall b', In b' lb -> p b') ->
q n.
So, in order to prove p_dec I would need decidability on predicate q (which you can assume I have), but also decidability on all b' for p....So you see my problem here :-)
I believe the solution will be something similar to the one on decidable equality shown on the link above...but how can I adapt it to my case?
Cheers!
Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600 dollars last year.
Marge: Bart! Don't make fun of grad students, they just made a terrible life choice.
- [Coq-Club] nested definitions, Nuno Gaspar, 02/21/2013
- Re: [Coq-Club] nested definitions, Pierre-Marie Pédrot, 02/22/2013
- Re: [Coq-Club] nested definitions, Jean-Francois Monin, 02/22/2013
- Re: [Coq-Club] nested definitions, AUGER Cédric, 02/22/2013
