- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: Dmitry Grebeniuk <gdsfh1 AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] appcontext question
- Date: Mon, 11 Mar 2013 13:37:55 -0400
Here are some examples which might elucidate the differences between [appcontext] and [context]:
Set Printing All.
Goal 1 + 1 = 2.
match goal with
| [ |- context[plus 1] ] => pose 1 (* fails *)
| [ |- appcontext[plus 1] ] => pose 2 (* this one *)
end.
match goal with
| [ |- context[plus 1 1] ] => pose 1 (* this one succeeds *)
end.
match goal with
| [ |- context[_ 1] ] => pose 1 (* succeeds *)
end.
match goal with
| [ |- appcontext[_ 1] ] => pose 2 (* succeeds *)
end.
The difference is that [context[?f]] only matches things where you have an [f] which is not applied to any arguments, for example, in [eq (plus 1 1) (plus 2 2)], [plus 1 1] is not applied to anything, but [plus 1] is.
There is an oddity when your head is a hole; I'm not sure what to make of it. For example,
Goal 1 + 2 = 3.
match goal with
| [ |- context[_ 2] ] => pose 0 (* succeeds *)
end.
Goal 1 + (id 2) = 3.
match goal with
| [ |- context[_ (id 2)] ] => pose 0 (* fails *)
end.
Note that it does not matter whether or not you have [context] or [appcontext] here.
-Jason
On Mon, Mar 11, 2013 at 1:19 PM, Adam Chlipala <adamc AT csail.mit.edu> wrote:
On 03/11/2013 01:17 PM, Dmitry Grebeniuk wrote:I believe [appcontext] only matches against genuine Gallina terms, not, say, sequences of arguments as in your example. You could think of [appcontext] as matching _prefixes_ of applications, whereas your example tries to match a strict _suffix_.
Require Import Arith.
Goal (plus 1 (id 2)) = 3.
match goal with
| |- appcontext [ _ (id _) ] => idtac "found"
end.
(* Error: No matching clauses for match goal *)
"context [ _ _ (id _) ]" matches the goal, and I thought
that "appcontext" could be used exactly in these
situations, since "plus 1 (id 2)" can be seen as partial
application: "(plus 1) (id 2)", so it could be matched
by "[ _ (id _) ]".
It seems that I don't understand "appcontext", right?
- [Coq-Club] appcontext question, Dmitry Grebeniuk, 03/11/2013
- Re: [Coq-Club] appcontext question, Adam Chlipala, 03/11/2013
- Re: [Coq-Club] appcontext question, Jason Gross, 03/11/2013
- Re: [Coq-Club] appcontext question, Dmitry Grebeniuk, 03/13/2013
- Re: [Coq-Club] appcontext question, Jason Gross, 03/13/2013
- Re: [Coq-Club] appcontext question, Adam Chlipala, 03/13/2013
