- To: Roberto Zunino <roberto.zunino AT unitn.it>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Peculiar type checking
- Date: Wed, 13 Mar 2013 19:17:03 +0100
Le Wed, 13 Mar 2013 19:08:32 +0100,
Roberto Zunino
a écrit :
> While playing with Coq, I was surprised to see that the following
> definition type checks:
> Require Import Bool.
> Definition prove_true (b : bool) : option (b = true) :=
> match b with
> | true => Some (eq_refl true)
> | false => None
> end
> The above looks strange to me because (eq_refl true) has type
> (true=true) which unifies with (b=true) only under the assumption
> that b unifies with true. That assumption is intuitively provided by
> the match, but how this actually works is not yet clear to me. For
> instance, it would seem possible to rewrite the above code as
> Definition prove2_true (b : bool) : option (b = true) :=
> match b with
> | true => @Some (b = true) (eq_refl true)
> | false => None
> end
> But this does NOT type check, as I originally expected:
> The term "eq_refl true" has type "true = true"
> while it is expected to have type "b = true".
> I am unable to pass an explicit argument to @Some to make it type
> check.
> Further, I tried the following:
> Definition prove_bool (b : bool) : sum (b = true) (b = false) :=
> match b with
> | true => inl (b = false) (eq_refl true)
> | false => inr (b = true) (eq_refl false)
> end
> This does NOT typecheck too, as expected:
> The term "inl (b = false) (eq_refl true)" has type
> "((true = true) + (b = false))%type" while it is expected to have
> type "((?16 = true) + (?17 = false))%type".
> Is there some way to write prove_bool ?
> Thank you,
> Roberto.
That is normal.
Just that Coq is sometimes smart and does not need all the required
stuff.
In the manual, see the pattern matching with "as … in … return …"
clause.
match b with
| false => None
end
must be read as:
match b as b0 return option (b0 = true) with
| true => @Some (true = true) (@eq_refl bool true)
| false => @None (false = true)
end
Same remark for your sum type.
- [Coq-Club] Peculiar type checking, Roberto Zunino, 03/13/2013
- Re: [Coq-Club] Peculiar type checking, AUGER Cédric, 03/13/2013
