- To: mtkhan AT risc.uni-linz.ac.at
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Resolving contradiction
- Date: Wed, 20 Mar 2013 15:08:19 +0100
Am 19.03.2013 11:39, schrieb
mtkhan AT risc.uni-linz.ac.at:
(j + 1%Z)Btw, for a minor technical improvement it might help to write (1 + j) or (S j), since plus is defined by recursiono n the left operand.
While the structure of 1 is well known to Coq (it's S O), the structure of j is not.
Thus the structure of (1 + j) is known to Coq (S j), but the structure of (j + 1) is not.
In any case,
I recommend using the following instead of this:
Parameter add_int: (list or_integer_float) -> Z -> Z.
Axiom add_int_def : forall (e:(list or_integer_float)) (j:Z),
((j <= 0%Z)%Z -> ((add_int e j) = 0%Z)) /\ ((~ (j <= 0%Z)%Z) ->
((add_int e j) = match e with
| Nil => 0%Z
| (Cons (Integer n) t) => (n + (add_int t (j - 1%Z)%Z))%Z
| (Cons _ t) => (add_int t (j - 1%Z)%Z)
end)).
Use something like:
Fixpoint add_int (e : list or_integer_float) (j : Z) : Z := ....
Or even better, try to use fold_left and firstn
(http://coq.inria.fr/library/Coq.Lists.List.html)
Definition add_int (e ...) (j ...) : Z := fold_left _ _ (fun a b => match b with
(Integer n) => (a + n)%Z | _ => a end)
(firstn j e) 0%Z
(I'm not sure on the syntax with Z and I haven't tried putting it into Coq,
so regard this as pseudo-coq)
Have fun with Coq,
Jonas
- [Coq-Club] Resolving contradiction, mtkhan, 03/18/2013
- <Possible follow-up(s)>
- [Coq-Club] Resolving contradiction, mtkhan, 03/19/2013
- Re: [Coq-Club] Resolving contradiction, Colm Bhandal, 03/19/2013
- Re: [Coq-Club] Resolving contradiction, Jonas Oberhauser, 03/20/2013
